flywheel sensor and crank sensor
08.05.2020 16:54 # 1
xpyhre
greetings prevent the flywheel sensor from starting the car? and where is this located? Does the crank sensor prevent the vehicle from starting? the location of this was in the barrier next to the hood in the right fender, what would this crank sensor look like? My vehicle is starting, the vehicle is not running? the right fendership had changed? I wonder if I broke my socket out? What does this piece look like on the publicservicebox? do these two sensors prevent the vehicle from starting?
08.05.2020 16:54 # 2
estair
exactly brother & nbsp; your car gets a starter but doesn't work on the 106s engine blog & nbsp;
08.05.2020 16:54 # 3
The flywheel sensor is the crank sensor you call. Number 5.
koliva 2012-07-18 00:43:23
08.05.2020 16:54 # 4
xpyhre
I think the crank sensor is not in this scheme.
08.05.2020 16:54 # 5
I think the [QUOTE = xpyhre] crank sensor is not in this scheme. [/ QUOTE]
I wrote wrong. I called the speed sensor instead of the crank sensor. This is the crank sensor I have shown above. It is located on the flywheel and informs the ECU about the position of the crankshaft. In other words, it helps to know which piston is where. When it is faulty, the vehicle will crank but it will not start.
