Fluctuation in headlights
08.05.2020 21:02 # 1
disocerydeli
good forums
My vehicle (307-2006) does not have a problem with the speed of the vehicle falling 1. When I put it in gear and pull my foot off the clutch, the headlights show a visible decrease.
What might be the problem?
Battery new
08.05.2020 21:02 # 2
Selcuk55
Charging device makes a missing charge
08.05.2020 21:02 # 3
GokhaN
[QUOTE = Selçuk55] Charging device makes a missing charge [/ QUOTE]
08.05.2020 21:02 # 4
beratsinaner
Greetings, I have 307 2006, I have been using it for 10 years, thanks to the experience.
08.05.2020 21:02 # 5
disocerydeli
We checked the values in the electrician, the values are normal
08.05.2020 21:02 # 6
ismailkaya
A (electrical) place draws too much current. can be a steering pump. It can cause current changes when it moves the steering wheel. If you install the battery's amperage with different amperage, you may have trouble. beratsinaner may be due to the dynamo as the friend says. (from the car's 1.4 90 hp gasoline)
