Flowing water from 206 heater core |
| 08.05.2020 16:31 | # 1 |
nurinuri58 |
my master is accumulating water under my 206's mop. I went to a master so they couldn't be better than you. He said that the calorie ferrule will burst and will change. the master said, maybe the pipe is cracked, maybe he is missing the connection, he said, there is no such possibility. I said let's change it well. He said that he would remove the front chest completely and find the same honeycomb and bring it. I think if this honeycomb is put under the chest & nbsp; this honeycomb does not come out before the chest rises & nbsp; pejo is a shame. won't this honeycomb come out from the bottom without the chest removed? I looked at the water right where the water came from & nbsp; I had a soft cover. besides, is there a problem with the supplier industry instead of the original? respects. div>
| 08.05.2020 16:31 | # 2 |
You can take the original one and change those pedals from the cover there. We are not master |
| 08.05.2020 16:31 | # 3 |
nurinuri58 |
Thank you brother in my eyes, you are now a master. Thank you.
| 08.05.2020 16:31 | # 4 |
[QUOTE = nurinuri58] Thank you brother you are a master in my eyes. Thank you. [/ QUOTE] |
| 08.05.2020 16:31 | # 5 |
| 08.05.2020 16:31 | # 6 |
djchaos |
If you disassemble the original and insert the original, you will get better results. I always say, even if there is a bolt, try to find the original and install it.
| 08.05.2020 16:31 | # 7 |
nurinuri58 |
Hey brother, I decided to get the original llama |
| 08.05.2020 16:31 | # 8 |
[QUOTE = nurinuri58] Eyvalah brother.I decided to take the original llama just be careful not to buy the original industrial product for its original money.
| 08.05.2020 16:31 | # 9 |
nurinuri58 |
it was probably not a writer named valio on it. Is there any supplier industry with valio brand?
| 08.05.2020 16:31 | # 10 |
[QUOTE = nurinuri58] is not likely to write valio on it. Is there any sub-industry with valio brand? [/ QUOTE] may not be able to write valeo. > div>
| 08.05.2020 16:31 | # 11 |
nurinuri58 |
The problem has been solved ... the heater turned out solid. they would start to rip the chest without knowing where to find honey in our district. 2 of the 3 screws in the connection points of the honeycomb and the pipe, have fallen, and I have made the leak leak. I don't know if we can write the name of the business here, but pejo & nbsp; A few friends leaving the service have opened new businesses. They took care of their hands.
| 08.05.2020 16:31 | # 12 |
nurinuri58 |
continues to flow. off offfff |
| 08.05.2020 16:31 | # 13 |
[QUOTE = nurinuri58] continues to flow. off offfff Most likely, your vehicle is parked while you are parked. The vehicle's engine is not hot when it is hot. I had already posted the action you had to do or have done in the forum. Assuming you have not read, I am sharing the link: Here you go: http://forum.peugeotturkey.com/forum_posts.asp?TID=20250&title=soutma-suyu-aracn-%DDine-szmas-problemi < br> |
| 08.05.2020 16:31 | # 14 |
nurinuri58 |
friends had not reached the master and did not change the orling in between. We changed orling no longer flows. It is saygılar ...
| 08.05.2020 16:31 | # 15 |
There is a problem with me.
| 08.05.2020 16:31 | # 16 |
Greetings, the same problem occurred in me. It was missing the connection point of the black pipe coming to the air conditioner. From the place where you have three bolts you said. I was tightened and it did not happen. With this process, my problem has been solved completely. I am glad that your problem has been solved. I think the general problem in water leaks is that the ohrings have to wear out and change.
| 08.05.2020 16:31 | # 17 |
nurinuri58 |
YES TWO GRAIN SEAL BALL HOW LIKE A LIRA BALL HAPPENED. |
| 08.05.2020 16:31 | # 18 |
My brother greetings. I'm in Kayseri too. I just bought the car. This trouble is out of print. Can you write where you made me have a special Kayseri? I find it too. I asked for the bikac on the floor in Kayseri, and we said that we had to fully distribute the car and sell half of it for scrap. help me brother
| 08.05.2020 16:31 | # 19 |
[QUOTE = nurinuri58] problem solved ... central heating. they would start to rip the chest without knowing where to find honey in our district. 2 of the 3 screws in the connection points of the honeycomb and the pipe, have fallen, and I have made the leak leak. I don't know if we can write the name of the business here, but pejo & nbsp; A few friends leaving the service have opened new businesses. They took care of their hands. [/ QUOTE] bro, greetings. I'm in Kayseri too. I just bought the car. This trouble is out of print. Can you write where you made me have a special Kayseri? I find it too. I asked for the bikac on the floor in Kayseri, and we said that we had to fully distribute the car and sell half of it for scrap. help me brother |
| 08.05.2020 16:31 | # 20 |
I would be glad if you share the result here :) |
