Flickering problem at idle after the first run
08.05.2020 14:57 # 1
BurcUMUL
Friends
Greetings to all. In my 206 GTI 2002 model car, after the first 2 months, I have a problem with idling after the first run. No problem when the engine gets hot. There is no irregularity in the tachometer, there was no problem with the computer. The oxygen sensor looks normal. However, the car and gearshift vibrate significantly.
I checked the engine chocks, there is no mechanical loosening. The throttle was cleaned but the result is the same. The idle regulator or idle valve that I can think of is faulty. How do I know this? Would it work to clean this part without changing it and if it has to be changed, does anyone know about the price? .
Thanks
08.05.2020 14:57 # 2
Did you get injectable cleaning, hic?
08.05.2020 14:57 # 3
BurcUMUL
As a result of the engine breakdown heat that came out during the surus, I connected the car to the computer and a temporary short circuit appeared in the 1st and 3rd injectors. I replaced it with the originals, but I did not replace the other 2 injectors or clean them. However, I used würth brand injector cleaning additive.
08.05.2020 14:57 # 4
BurcUMUL
I ordered idle engine 170 TL original. I hope everything goes well?
08.05.2020 14:57 # 5
Don't throw away the old one. Actually, I think the event is not like the engine of the idle, but I hope it will improve ...
08.05.2020 14:57 # 6
BurcUMUL
[QUOTE = cecoli] don't throw away the old one. Actually, I think the event is not like the engine of idling, but I hope it will improve ... [/ QUOTE]
What is your opinion? . When I go to the service, I have it checked. I would be glad if you share.
08.05.2020 14:57 # 7
BurcUMUL
Could I make this idle from the ignition coil or spark plug and cable? ...
08.05.2020 14:57 # 8
Firstly, I thought that injectors could be broken. but it is necessary to look as it may be related to heat or oxygen problems.
08.05.2020 14:57 # 9
BurcUMUL
Will the error on my heat and oxygen sensor appear when the car is connected to a computer? . Because when it was connected to the computer, there were no errors in the memory, neither present nor present.
08.05.2020 14:57 # 10
solo206
When I was idling 1-2 times, I had a tremor and a drop in speed. The malfunction lamp was on. I got it to the computer right away. It turned out that there was a problem with the single ignition coil as a problem. Master said no need to change. There was a similar turnover decline last weekend. The malfunction light came on again. I went to a private peugeot service. On the way to the road, you took gasoline in the petrol, then I saw that the malfunction lamp went off. When I arrived at the industry, the master said that there might be dirt on the gasoline, so it might have been. I put it on the computer again, the ignition coil was the only problem. There was no original in their hands, I did not change it. They said it would not be a problem ...
08.05.2020 14:57 # 11
delta0o
In my 106 GTI, there was a problem with idling, we changed it from the idle engine, it was corrected when we found out that the problem was from the crank sensor as a result of long searches, and it was still okay.
