Flickering problem at 307 - 90Km-100Km speed
08.05.2020 18:50 # 1
yusufsemi
Hello friends
My car is 2006 model 1.6 LPGli 307. I have a new starting tremor problem. While trembling is felt at low speeds, it starts when the speed reaches 90 Km. While there is no tremor in the steering wheel, I feel the car trembling in the right-left direction with my whole body. Even if the passenger seat is empty, I can see the seat shaking.
What could be the reason for this tremor?
08.05.2020 18:50 # 2
Ahmet_ach
Usually it makes the balance adjustment, but if the tires are 5-6 years old, it loses its properties and makes a tremor.
go to the tie rod connector first, see if the tires are not in order, see the production date of the tires.
08.05.2020 18:50 # 3
yusufsemi
I forgot to mention the balance. I'm sorry. I had winter tires last week. All tires have been balanced recently. To the best of my knowledge, the imbalance causes tremors in the steering wheel. In mine, the body of the car trembles.
08.05.2020 18:50 # 4
okan77
If this is not the case before, I recommend you to balance it from the ground again, this time .. It is always good to start with the cheapest.
08.05.2020 18:50 # 5
aokaymaz
If the steering wheel does not vibrate, the rear wheel may be out of balance or, most importantly, they may have left the wheel bolts loose.
08.05.2020 18:50 # 6
Ert.Kckrk
If the problem does not come out of the tires, I would like to have the bidet look at the axle shaft. I had the same problem on my 206 vehicle, my axle shaft changed problem was solved
08.05.2020 18:50 # 7
yusufsemi
Let me give information about the developments.
The axle shafts were removed and the spring on the triple ball called tulip in the left axle was broken. Instead, it is not the same but a similar spring was adjusted and installed.
The result did not tremble. On the contrary it has increased even more.
Now, I will look at the rod settings and the balance settings. If it still doesn't flicker, I will change the axles.
08.05.2020 18:50 # 8
oguzhan53
There was a similar problem for me, but mine was doing it at 140, they said I went from the tires, I got michelin primacy 3 again, the same balance was done, it did not improve, they said the ball again, I changed the ball 4 times again, it did not improve again, finally the engine bottom chock was noticed and it was changed at the moment, there is no gram tremor. Have a look. oguzhan53 2014-11-18 19:45:49
