Flickering problem
08.05.2020 19:34 # 1
ozgorh
Hello friends, my car is shaking at idle, can cause both lpg and gasoline
08.05.2020 19:34 # 2
pusutr
have the motor ears checked.
08.05.2020 19:34 # 3
palet
Diesel or gasoline? Diesel se; there is a possibility of an air flow meter. If you have a flow meter error when you connect your vehicle to the computer, replace it with a Siemens or Sagem brand flow meter. If you install Magnetti marelli brand flow meter, the computer will not give error but your tremor failure will continue.
If your vehicle is Gasoline, it can be a conjector. make sure that the charge voltage does not cycle at 14.50 volts at idle.
08.05.2020 19:34 # 4
KILIC
Possibility of the ears yukswk
08.05.2020 19:34 # 5
berker16
90% ear
08.05.2020 19:34 # 6
ozgorh
By the way, he only plays on the needle
08.05.2020 19:34 # 7
Mert78
I think throttle or coil
