Flickering in the headlights
08.05.2020 20:07 # 1
Yusuf307
Hello friends, I did not find the problem in the Peugeot 307, I did not connect the car to the computer, I did not want to give money to my car yet, there is a power fluctuation in my car, the battery has just changed, the alternatore is intact, the engine is shaking at idle, do you think this could happen? said there may be looseness or defect in the conjunctor
08.05.2020 20:07 # 2
pepecura
Can you shake the engine at idle?
What is the idle age?
08.05.2020 20:07 # 3
barishrocker
I'm following
08.05.2020 20:07 # 4
palet
If you are confident that the flickering of the headlight is due to voltage, there is a malfunction in the connector inside the charging dynamo. If you see the same flickering in the light of the trip computer when the headlight is also flickering, it is the definitive connector. palette 2017-01-06 14:13:50
08.05.2020 20:07 # 5
ggitaristt
Is there a shortage of electricity when the engine is idling?
08.05.2020 20:07 # 6
barishrocker
How is the bulb status? The bulbs in me do not last too long. Usually the left side goes.
08.05.2020 20:07 # 7
Narkotik
I advise you to make a cable bypass from battery to alternator
08.05.2020 20:07 # 8
Fthz
Most likely, the conjector, to find a beautiful master. I suggest you take a look at the general condition of the wiring of the electrical installation. After all, old vehicles. While I was buying and selling the car, the expert suggested that we renew the electrical installation.
08.05.2020 20:07 # 9
Yusuf307
Thanks for your answers, I suspect the spark plug, I have changed it, it is already finished.
08.05.2020 20:07 # 10
Yusuf307
I can do if you can explain how to bypass the aquarium alternatore.
08.05.2020 20:07 # 11
lazianke
Headlight flickering on steering angle sensor malfunction on Skoda fabian post 2001 models laziank to 2017-01-13 22:13:33
08.05.2020 20:07 # 12
Yusuf307
No, this is something that happens from time to time. It is fixed after you know that you have pressed the marsa. There is no problem when the calista brakes on departure. I just bought it.
08.05.2020 20:07 # 13
barishrocker
[QUOTE = Yusuf307] No, this will happen occasionally, there is no problem after you press the marsa you know.
Do the bulbs burst easily too?
