Flickering in cold engine
08.05.2020 21:17 # 1
Kenblock06
Friends vibrate when the engine is cold, it does not get hot, but it decreases compared to the cold engine. Today I bought the obd device, while the pointer is at 90 degrees, the obd device shows 99-100 degrees. Why does this happen?
In addition, sometimes the vehicle does not eat gas and stopped 2 times on the way to the 2nd test when going on the road. Why does this problem occur? The fault light also comes on in the vehicle.
08.05.2020 21:17 # 2
x571
What does RRe burn and say? You have to look at it. It seemed like an ignition problem.
08.05.2020 21:17 # 3
Kenblock06
teacher classical oxygen sensor failure error
08.05.2020 21:17 # 4
Kenblock06
[QUOTE = x571] What does RRe say? You have to look at it. It seemed like an ignition problem.
[/ QUOTE] teacher classic oxygen sensor failure error
08.05.2020 21:17 # 5
x571
[QUOTE = Kenblock06] teacher classic oxygen sensor failure error [/ QUOTE]
Clean and reattach the sensor with oil-free contact spray. I guess the new one was 500 LIRA if it was really broken. The same ignition system also makes malfunctions. If you want to look at a few places. Take it to a place with pp2ooo. When they say there, they should not rob.
08.05.2020 21:17 # 6
aydinbslm
Hello teacher, how can you write where you got the malfunction here?
08.05.2020 21:17 # 7
KILIC
When it is cold, it may be from the upper ear of the engine. If the malfunction light is on, you can fix it by connecting it to the computer. Stopping where it goes can be caused by a lot of things. When the engine is hot, it can stop the car from crank speed sensor if it is difficult to start or not.
08.05.2020 21:17 # 8
Kenblock06
[QUOTE = aydinbslm] hello hello can you tell me where and how you got the fault here same problem exists in me [/ QUOTE] Hello teacher, I haven't made the fault yet. I suspect overheating. As soon as I am going to buy and change the temperature sensor.
08.05.2020 21:17 # 9
Kenblock06
[QUOTE = KILIÇ] It may be from the upper ear of the motor when it is cold. If the malfunction light is on, you can fix it by connecting it to the computer. Stopping where it goes can be caused by a lot of things. If the engine is hot, it is difficult to start, etc. If there is a situation, the crank speed sensor can stop the vehicle. Somewhere there is an error, but I could not solve it. When the temperature is 90, it shows 96-97 in the ecu brain. I was tempted by the heat. I think to check the cables and replace them as soon as possible.
