Flickering at Takeoff
08.05.2020 17:26 # 1
MuRaTTTT
If I do not give the gas too much in the first take-off, what is the reason for the tremor?
A couple of friends who had a similar issue in the form before, but there was no clear answer, said the clutch wire, but if the problem is not caused by this, let's not change it in vain.
08.05.2020 17:26 # 2
206xt
Yes, I have the same problem. I am waiting for the comments.
08.05.2020 17:26 # 3
SDYMZ
printing can also be from pads
08.05.2020 17:26 # 4
impact
I have also said that the ear of the motor is cracked or something but I do not have the technical knowledge ..
08.05.2020 17:26 # 5
taskin
When I changed the pressure pad, I encountered such an excessive vibration problem, they said that the problem was caused by non-original pressure pad, but after a while I read that the clutch wire of these vehicles was very gentle in the forms and changed the problem after the 80% was done and when the 10000 km was completed, the pressure pad was used to each other and boredom. over. There is a possibility that the clutch wire can be ...
08.05.2020 17:26 # 6
MuRaTTTT
Nobody knows clearly. I didn't get to the master over the weekend, but if I had a clear information, let me change the pressure on the pad.
08.05.2020 17:26 # 7
as far as I know there may be problems with the motor ears
