flickering at a certain speed! (improved)
08.05.2020 15:37 # 1
Friends are trembling when I drive 85-90 km / h with my vehicle. balance adjustment, rot adjustment, I have done all of them.There is no normal problem in tires. It doesn't matter in gear or idle. She's trembling while she's down. not only the steering wheel but the entire torpedo is shaking. I think it could make an axle shaft. I am waiting for the sharing of my friends with knowledge. Thanks in advance for your help
respects
the pugt 2011-06-22 19:53:38
08.05.2020 15:37 # 2
Get well soon. It may be an axle, but have you ever tried to change the tires to the rear? the cecol 2011-06-14 09:53:28
08.05.2020 15:37 # 3
[QUOTE = CeCoLi] might be an axle, but have you ever tried to change the tires ten rear? [/ QUOTE]
Thumbs Up I would say the same thing
08.05.2020 15:37 # 4
Let [QUOTE = CeCoLi] be past. It may be an axle, but have you ever tried to change the tires to the rear? [/ QUOTE]
thank you. yes I did a tire change. I did it in the balance, the rot was in the adjustment, but the problem continues.
08.05.2020 15:37 # 5
At this point, being an axle rises up Unhappy
08.05.2020 15:37 # 6
but I think which one might be. right or left or both! will it detect my tie rod?
08.05.2020 15:37 # 7
I looked at the axle prices and found the right hand left for 125 TL. we will make the assembly free
08.05.2020 15:37 # 8
[QUOTE = pugti] but I think which one might be. right or left or both! will it detect my gunner? [/ QUOTE]
It should be controlled by a qualified master. Do not take it apart without a doubt, you will look at it from another place.
08.05.2020 15:37 # 9
My master said it was off the axle shaft. He explained the situation when we got into the experience, but at first he made the balance if he did not stop trembling, he said it was wrong, but I did not go into detail. The front rods swing rod heads have just changed, so at the beginning of the year. rot shaft doesn't do anything, cem? I replaced the left tie rod shaft. I wonder if there was a problem on the right.
They said there was looseness in the right tie rod end they said I could not get out of the science in the biker and I went to the service immediately and we found that the screw in the right tie rod was crooked and the problem was fixed. it even trembled at low km before replacing screws, but the problem was resolved and the tremor disappeared. but now there is tremor at this speed
08.05.2020 15:37 # 10
I do not expect it to be from a tie rod, because it makes a certain face. not under or above. But the car is unclear from where to get this sometimes
08.05.2020 15:37 # 11
Do you think it is inconvenient to install the original axle shaft 400tl sub-industry?
08.05.2020 15:37 # 12
mdincer34
In my car, there is a problem with pulling the bear to the right and excessive tremor zero tire, mn tool zero rot setting was done 3 times as a last solution, I changed the front seams and pads now, 130 140 or so tremor zero. most probably the firen discs were warped. my brake discs were good image but i mean it was changed problem zero.trw original disk and pad I got the problem improved.
08.05.2020 15:37 # 13
I changed pads and discs last Friday Disapprove
08.05.2020 15:37 # 14
dinoco
Ouch If it is more fleshy, we can mill the distorted discs on the lathe without changing them.
I hope Kenan is solved in the most economical way.
Dinoco 2011-06-15 00:06:54
08.05.2020 15:37 # 15
[QUOTE = Dinoco] Ouch If it is more fleshy, we can mill the distorted discs on the lathe without changing them.
thank you Thumbs Up if I do not install the axle shaft supplier industry. original high price
08.05.2020 15:37 # 16
307P
Well, how much is the supplier industry?
08.05.2020 15:37 # 17
I agree with friends as far as I have read it may be an axle the albaydemirc 2011-06-15 08:39:15
08.05.2020 15:37 # 18
Thank you, Ahmet, I hope there will be no more problems
08.05.2020 15:37 # 19
[QUOTE = pugti] thank you ahmetcim I hope there will be no more problems [/ QUOTE]
i reca kenan brother cause cause ins no other problem bro Gülme
08.05.2020 15:37 # 20
I figured it out, guys. the right front tire of the vehicle came out defective. we even disassembled the tire and rim and put it back on. For now there is no problem.
Page : / 2
