flickering and shivering sound when pressing the gas
08.05.2020 19:48 # 1
mjtanju
hello when you press the gas on the straight road, for example, 2 gundue car is shaking.
08.05.2020 19:48 # 2
mjtanju
does anyone know
08.05.2020 19:48 # 3
Now I have a few questions. When I say takur tukur ses, is it always a sound that comes up or if I am going to move my gas pressure, this sounds. I have LPG in the vehicle, I think you are having the same problems with gasoline.
08.05.2020 19:48 # 4
mjtanju
[QUOTE = sonerkyl] Now I have a few questions, and when I say the sound of the tide, it is a sound that comes continuously or if I press the gas pressure, it sounds. I have LPG in the vehicle, I think you are having the same problems with gasoline. [/ QUOTE]
gas comes only when it comes to gas.
08.05.2020 19:48 # 5
Turn off the LPG and use it in a little gas. Let's see if the same sounds continue. If this sound comes from the engine, the vehicle's sentence setting may be impaired. When was the last time the timing changed. or any part in the engine compartment may be loose. pulleys bearings etc.
08.05.2020 19:48 # 6
mjtanju
[QUOTE = sonerkyl] Turn off the lpg and use it in a bit of gas. Let's see if the same sounds continue. If this sound comes from the engine, the vehicle's sentence setting may be impaired. When was the last time the timing changed. or any part in the engine compartment may be loose. pulleys bearings etc. [/ QUOTE]
2 days ago I changed the disc to zero pad.
08.05.2020 19:48 # 7
Dadas-25
How does the brothers exhaust condition change if there is no curling etc. No stopping exhaust change?
08.05.2020 19:48 # 8
dagdelen34
If the body trembles when you press the gas, the axle should change.
