Flickering after 80-90 km speed?
08.05.2020 19:13 # 1
yusuf333
I just joined your friends, I have a problem, I would be glad if you help me to solve it.
my vehicle is 206 color line 2001 model,
While I was driving a long way last week, a tremor started in my vehicle after 150 km. When it reaches 80 or 90 km speed, the tremor occurs, the gas is cut off, the gas is tremendously felt when pressurized. at the same time, when he looks at the gear lever, he also has a tremor, what is the reason, what can I do?
It has been 2-3 months since I was troubled by the problem immediately :(
yusuf333 2015-04-19 16:37:40
08.05.2020 19:13 # 2
tezmert
if it only does when you press the throttle, it is probably due to the right or left axis.
08.05.2020 19:13 # 3
talip206
Have the spark plugs checked. someone might be burnt. He was on the back of a friend, he did not reveal himself at low speed. When it speeded up a bit, there were events such as falling from traction, trembling. We looked at the spark plug from its place
08.05.2020 19:13 # 4
hakao
I had the same problem in me, it was trembling when I passed 90. I changed the tires, we got into the balance, the problem got better. Have a look at the tire balances.
08.05.2020 19:13 # 5
Alicilik
When the gas is cut, it improves that the problem will be caused by the engine or transmission.
If it is caused by axle or ball, it is not cut with gas.
08.05.2020 19:13 # 6
GokhaN
[QUOTE = Receivability] When the gas is cut, it improves that the problem will be caused by the engine or transmission.
+1
08.05.2020 19:13 # 7
fætih
the transmission ear or the engine ear may be broken. the balance lead may have fallen. gotta look ...
08.05.2020 19:13 # 8
yusuf333
Axle
Spark plug
Rot balance
Engine ear
Transmission
Everybody said something different. At the first check, the master replaced the spark plugs. Problem not solved. He said it is likely to be an axle. We take the axles right and left complete. Let's see if we change it. This is just the construction problem. If we enter the gearbox, isn't there a higher cost?
08.05.2020 19:13 # 9
yusuf333
Rot and balance had been done before.
08.05.2020 19:13 # 10
xmen
It is certainly not from the engine's ear ... if there is any shaking in the idle, we can say that the engine is the ear.
08.05.2020 19:13 # 11
yusuf333
No, it is shaking when you press the gas even when it is 100. The shaking is zero.
08.05.2020 19:13 # 12
Erhan_Gti
I have the same problem in me, if my friend changes the axles or if you let me know how it improved here you will help me thank you :)
08.05.2020 19:13 # 13
yusuf333
The master right-hand axle said it was problematic, I bought both the right and left. We changed the axles. And thank God the problem of tremor has improved. :)
If there are friends who have the same problem, they should know that there is an axle.
But be careful, your complaint must be the same. Different complaints indicate that there are different problems and different solutions.
Best regards...
08.05.2020 19:13 # 14
yusuf333
Muhakkah rod should be made after the axle change. This is extra information :)
01.09.2023 04:31 # 15
Abdullah51
Good day brother, I also have a vibration that starts after 90, it is not in the steering wheel, it lasts until 110. Is my problem the same, do you think?
24.10.2023 23:54 # 16
Ahmtyt
I've revived this topic with my new experience. It just happened to me. When I was driving on a straight road, I heard a slight clicking sound and it started to vibrate. It fixes itself for a moment but then it comes back and only happens when I press the gas. This usually happens after a certain speed, but it hasn't happened in the city. There is no problem when I release the gas pedal or press the gas in neutral. The axle, exhaust, spark plugs, engine-transmission mounts have been written. Let's get experienced when going to the mechanic. Has anyone found a definitive solution?
