FLASHING STOP LAMP?
08.05.2020 17:39 # 1
kuscu38
my friends hello vehicle 306 1.6 xs there is a flashing light in between, but there is no problem in the vehicle insistent to extinguish :) I am with friends in the industry every day, but there is no fault, the master looks at it, there is no problem.
08.05.2020 17:39 # 2
Bunyamin.Kar
Check the engine oil level, and even though there was no problem for me, it went out after the oil change to not burn again :)
08.05.2020 17:39 # 3
samet206
I suggest you look at the electrician, even if there is no mechanical problem, maybe there is an electrical problem ...
08.05.2020 17:39 # 4
reality59
check your fuses it may be water, cut
08.05.2020 17:39 # 5
kuscu38
friends, thanks for your suggestions, but i am working with your friend during the day during the repair, i did the oil change myself i even added the additive :) We looked at the electric part completely from the ground up, but since the reversing lamp was not in the particle, it remained incomplete, I never thought of it. There is a gap in the bidet flow ball, we did not make it because it did not bring the ball to the particle, but it will come on Tuesday, after these are done, it will burn to the lamp and there is a fault sign in connection with it. Thank you all in advance.
08.05.2020 17:39 # 6
howard
If the oil filter is not original it stems from it brother or have I changed a piece recently? If the brake fluid is alerted as it accelerates, the brake fluid may have decreased. or water may be depleted, if none of these are in the seal that measures them :)
