Flashing Point Next to Digital Air Conditioner
08.05.2020 20:09 # 1
JunioR56
First of all, hello to everyone, I wish you days without fail: D
I have a 2003 1.6 lpg xt model peugeot vehicle, the problem is this: the heater engine is running and not running. I ride in the evening does not work when I get on the next day and it does not work anymore. All functions of the digital air conditioner are working. When I turn on the air conditioner, the engine is activated, but the ventilation engine inside the vehicle does not work and the dot mark flashes next to the rating. What does that dot sign mean? They are not mentioned in the manual in the dot sign. Has anyone ever had anything to do with it? I will check if there is energy to the engine at the weekend and remove the air conditioner screen and put it back on.
08.05.2020 20:09 # 2
I recommend you to examine the subject, you can find many topics in the forum about such problems.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=43335&title=kalorifer-uflemiyor-acil-yardimm
08.05.2020 20:09 # 3
JunioR56
I have been studying for 3 days, I could not find it, so I had to open a subject. I'm sorry.
08.05.2020 20:09 # 4
no matter what's wrong, teacher, check the cables in the picture
08.05.2020 20:09 # 5
JunioR56
As you said, I checked all the possibilities. I dismantled the car and continued outwards. I found the insurance going to the engine from the internet. The fuse has melted and a bit of it is needed. I changed the fuse again, it didn't work. I went to the electrician, it was closed, I got angry and bought sandpaper from the painter. Evil Smile
I sanded the terminals of the battery and the cables we connected.
I put the insurance on again. I opened the boiler and the point at the end of the degree went out. BAM.
I speeded up the fan.
Abs, esp, handbrake foult error 2 days before doing this operation.
It had happened to me before, the battery + pole was loose. I fixed it up today. Probably it will be fixed in that problem.
Has anyone come to a definitive solution beforehand?
