Flange & Spacer?
08.05.2020 16:15 # 1
lkr_yldz
friends 206 my car has a steel rim but it looks like my rear tires are inside. and I learned something new, they put a disc-like thing called a flange or spacer between the wheel and the caliper so that the tires are a little more out of the way. My question is, if I just put it on the rear tires and put it on, it would cause any problems for my vehicle and me. I expect help and information from friends who use or know.
thanks in advance ...
08.05.2020 16:15 # 2
I don't know if it is a problem, but you will definitely need to change the bolts
08.05.2020 16:15 # 3
ilker hello ... there is not much rim option in our peugeot .. there are so many beautiful wheels on the market that it is not due to offset, unfortunately ... most people use flanges to be ... I am also suffering from the same trouble ... but I am a bit afraid to use flanges ... because when I put a flange, I know that the studs will change .. so I will have to put on longer studs, which scares me ... also, if you do, apply it to 4 wheels .. just by doing it behind the back of the vehicle, I think ... completely personal opinion ... those who have detailed information about this will help. ..
08.05.2020 16:15 # 4
OkaN
neither you need to change the wheel bolt nor does it harm. even find the front 2 diks, make them old, if you want to be thick in the lathe, if you want too thick, then the studs may not catch up, the bidet should keep the studs low :)
08.05.2020 16:15 # 5
lkr_yldz
what cons the long wheel bolt brings to me Is it like a bolt cut. The dislocation of the front tires seems normal to me, but the rear feels very inside.
08.05.2020 16:15 # 6
OkaN
Then do not make a very thin 1 flange. DosTum;)
08.05.2020 16:15 # 7
34sea45
the sky is at 106 xr and the flood is quick & nbsp; it does not cause any trouble, but how many cm users also have something called spacers in the spacers, I think you have to look at that.
08.05.2020 16:15 # 8
zavur
I say for the safety of playing with the original of the walking gear.
08.05.2020 16:15 # 9
OkaN
how encrypted wheel bolt brother has no such thing: D of course I made it myself:) & nbsp;
08.05.2020 16:15 # 10
lkr_yldz
how are they sold?
08.05.2020 16:15 # 11
OkaN
Why do they want to pay the world's money? & nbsp;
08.05.2020 16:15 # 12
34sea45
encrypted wheel bolt < br>
If you're going to do something with a hitch, you won't look at 3 reputation 5
08.05.2020 16:15 # 13
lkr_yldz
I did not ask more, or rather I did not have the opportunity. my studs are already encrypted if this & nbsp; if I put the tools on them, they will be wasted
08.05.2020 16:15 # 14
How do I need to change the wheel bolts my friend has a mind logic, you are expanding as a result you will trust the wheel of the bolt 2 cm with 2 cm flange, you will rely on what you will hold with 2 cm. I do not enter keys in their holes, they use encrypted wheel bolts for them. I use them in my car.
08.05.2020 16:15 # 15
[QUOTE = lkr_yldz] friends I have steel rims on my 206 cars but my rear tires are very inside. and I learned something new, they put a disc-like thing called a flange or spacer between the wheel and the caliper so that the tires are a little more out of the way. My question is, if I just put it on the rear tires and put it on, it would cause any problems for my vehicle and me. I'm waiting for help and information from friends who use or know.
thanks in advance ... [/ QUOTE]
I wouldn't recommend it.
Dangerous at high speeds.
08.05.2020 16:15 # 16
lkr_yldz
It is certain that it will not be changing the wheel bolts when it comes to work.
08.05.2020 16:15 # 17
OkaN
bro I am using it!
08.05.2020 16:15 # 18
34sea45
If you are going to use this
1 you will be using long wheel bolts (not handmade, but not a fabification long wheel bolt). You will get it in the industry to get 2 cheap, you will be going on 4 wheels, you will get the money produced by companies like Oz Yed. work
08.05.2020 16:15 # 19
If you take the flange from the solid place, it will be very useful if you fit the bolts in a long or short way. If you are going to do it as my brother said, definitely make it in the same dimensions in 4 wheels.
08.05.2020 16:15 # 20
[QUOTE = OkaN] or brother I use it!
My brother is using it, but the bolts will remain open as long as they should enter. If you take it out and put a stamp together, it will not fit in your hole.
Page : / 3
