|   | fires that may escape on vehicles |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 13:55 | # 1 |
|  Guests | |
|  FIRE IN VEHICLES  If the fire in the vehicles is not prevented, a great tragedy will occur. It may come. Evaporated gasoline ignites causing the tank to catch fire It happens. After a while, the vehicle may explode. Smoke detected in the vehicle the moment must be stopped. Then the contact must be closed on the key. Care must be taken not to lock the steering wheel. Otherwise, it should otherwise, the vehicle cannot be pushed. All passengers carefully should be taken. It should be opened as the bonnet part. So your flames growth is prevented. If possible, the battery terminal should be removed. Fire should be used if extinguisher; if not, from the blanket or car cover It should be utilized. These covers will prevent the flames from getting oxygen and growing. Airless flame goes out. The incident occurs on a sand ground If it has come, it can be extinguished by throwing sand over the flame. | |
| 08.05.2020 13:55 | # 2 |
|  Guests | |
| Thank you for sharing. | |
| 08.05.2020 13:55 | # 3 |
|  Guests | |
May Allah not show it to anyone, thanks for the information you provided.
| 08.05.2020 13:55 | # 4 |
|  Guests | |
| Thank you for sharing ... | |
