Finally Triger has changed
08.05.2020 16:27 # 1
albayman
About 10 days ago I bought the original timing set and circulation from Şahin Peugeot and I couldn't find any time. the butterfly neck was also cleaned and calibrated. The T connections of the pipes to the lpg regulator were plastic and were missing, these were replaced by metal ones. no leakage has been prevented. >
workmanship: 125 tl
T connection 2 pieces: 5 tl
Mobile antifreeze: 17 tl.
& nbsp;
It cost me 360 TL. How do you think the price is?
albayman 2011-12-14 20:34:49
08.05.2020 16:27 # 2
maestro
good price good
08.05.2020 16:27 # 3
mon
just how much is trigier crafting? do you know? & nbsp; mon 2011-12-14 15:46:39
08.05.2020 16:27 # 4
albayman
he only wanted $ 100 for timing labor.
& nbsp;
actually asked before I took the materials, gave the prices like this:
timing: 200,
I'm in circulation: 100
workmanship 100 & nbsp; so a total of 400 said. butterfly throat and other operations were not involved. He was surprised to hear the price I bought, his face fell a little more, he didn't believe it. & nbsp; when he saw the peugeot bill, of course he believed :) low speed 2nd gear around 1000 rpm with half clutch, there was a bit of shaking and shaking problem, gas reaction came a little late. these problems have now improved. The vehicle's responses have improved a little more ...
& nbsp;
butterfly cleaning cut 150 to timing & nbsp; crafting, including calibration and t connections, I had 25 more by bargaining.
I gave it to 125 workers. Actually it is a little too much, but MUĞLA, I got used to it, PARAGÖZ ESNAFA. my spark plugs didn't need to be changed anyway.
now catalyst and lambda cleanings are left ...
08.05.2020 16:27 # 5
djchaos
the price is very very good, sponsor of the forum, hawk peugeot tan, i have been shopping, i can recommend it both smoothly and very good price.
08.05.2020 16:27 # 6
albayman
Meanwhile, butterfly cleaning was not a very difficult thing. It is a bit of a problem that he disassembled the previous parts and himself until he reaches the butterfly. the man holding the key is difficult until he learns only once. When he learns, he does it himself. but pp2000 is a must for calibration. so we are in the service again ... "Thumbs
If I buy zero vehicles, I will definitely want to sample computer connectors
08.05.2020 16:27 # 7
Ali
Timing change distressed business prices are good.
08.05.2020 16:27 # 8
ose
Prices are very good. If Sahin was not a peugeot, he had done it.
08.05.2020 16:27 # 9
albayman
Thanks to Şahin Pejo once again ...
Let me give you an information immediately:
There are two places where the cooling water is bled. I couldn't see one from the heater, the other from somewhere on the engine. that is, the air was taken from 2 places while the air was getting air. we also waited for the water temperature to rise, and it worked quite a lot at idle. He gave gas in the meantime, so that the circulation would go fast. Also, while climbing the Muğla University slope, the instant consumption that always travels above 15lt is around 13-14 lt. It seems to me that the overall collection will be reflected. I am now seeing 6lt figures in instant consumption while driving at a speed of 80-90-100km on the straight road. It wouldn't go down to 7-8.
08.05.2020 16:27 # 10
sahin-peugeot
Thank You ...
I'm glad your problem is resolved,
08.05.2020 16:27 # 11
oguzhandincel
I got the price for 306 and I will get the timing and circulation as soon as possible. I found a master in Çorum wanted 100 TL to change.
08.05.2020 16:27 # 12
aspirinxlarge
Do I need to go back to control when Friends Triger changes, & nbsp; the repairman said, let's look at the tensioner 15 days later, I was not there for 1 month.)
08.05.2020 16:27 # 13
albayman
I was told the same. Come back 2 weeks later, I will check the belt tension, he said. taking the stretch of the strap into account, it made it a little tense than it should have been. It becomes normal with a stretch share within 2 weeks. he will check and adjust the tension if necessary, he said.
