Finally the problem is solved ...
08.05.2020 20:44 # 1
Peugeot35
I think that I have come to the end of the problem that I have been experiencing for 2 months, my problem is drowning and exhausting water during fluctuation + idling and stop + shake, and due to these reasons, my fuel consumption has increased, traction has dropped, the engine has started to work with voice, additional upper oxygen to them The engine malfunction light from the sensor was steady and the & nbsp; antipollution fault error was fixed on the screen.
As I said last time, I have used this way for 2 months, special peugeot services included normal repairers said that we could not solve the problem. As of yesterday, he went to work in the first way as he worked in the gas as he went to work, he moved to LPG in progress and after he started not to gas at the stop and excessive shock started & nbsp; on the trip computer, he gave a catalytic converter error and the engine fault light flashed, then again & nbsp; antipollution fault error was found after 2km. everything was back to normal by forcing it to drive.
I have previous topics & nbsp;
https://forum.peugeotturkey.com/forum_posts.asp? TID = 45535 & amp; title = 307-idle-drop-and-ripple
https://forum.peugeotturkey.com/forum_posts.asp?TID=45686&title=307-rolanti-sapitmasi
Reviews
https://forum.peugeotturkey.com/forum_posts.asp?tıd=45470&title=antipollution-fault
Reviews
Reviews
I connected it to the computer today, there is the 1st cylinder ignition error now what does this mean all the problems are from the coil or spark plug or this error is in my problem !!
< edited> Peugeot35 2018-02-16 00:02:41
08.05.2020 20:44 # 2
talip206
Coil can be. It is very easy to control. I don't know 307, but 206 is just above the spark plugs on the top of the engine block. It holds two screws. Disassemble the coil, pull out the soft plastic parts at the end. If the copper ends have oxidation, if there is foliation, the coil is defective. If the coil failed, it also broke the spark plugs.
http://www.peugeotmarket.com/peugeot-307-16-benzınlı-bobın-orjınal,pr-224.html
08.05.2020 20:44 # 3
Peugeot35
[QUOTE = talip206] Coil may be. It is very easy to control. I don't know 307, but 206 is just above the spark plugs on the top of the engine block. It holds two screws. Disassemble the coil, pull out the soft plastic parts at the end. If the copper ends have oxidation, if there is foliation, the coil is defective. If the coil failed, it also broke the spark plugs.
http://www.peugeotmarket.com/PEUGEOT-307-16-BENZINLI-BOBIN-ORJINAL,PR-224.html [/ QUOTE]
307 is holding the same two screws There is 1 socket but because it is an electronic card, it may not be evident. I have a delphi brand on top of mine, it is also going through the original peugeot and the citroen logo.
08.05.2020 20:44 # 4
emretprmz
I have the same problem. I changed the engine wedges because it was very old, the throat was cleaned in the butterfly, but there was no solution. If you reach the result, please inform us ...
08.05.2020 20:44 # 5
Peugeot35
[QUOTE = emretprmz] I am having the same problem. Since it is very old, I changed the engine chocks, the throat was cleaned in the butterfly but there was no solution. If you reach the result, please inform us ... [/ QUOTE]
I think it is probably a coil, I change the coil and spark plugs on my weekend vacation, I write results.
is your 307 xr?
08.05.2020 20:44 # 6
emretprmz
2004 model xt teacher. If yours gets better, let's do it with us. The original coil is still on it. emretprmz 2018-01-22 08:47:28
08.05.2020 20:44 # 7
Peugeot35
State of End;
To the computer connected and any errors;
< font face = "Arial, Helvetica, sans-serif" size = "3"> * Continuous malfunction, combustion kicks cylinder 1
* Continuous breakdown, wealth regulation suitability
* Intermittent breakdown, 2 brake contactors incompatibility between
* Intermittent malfunction, upper oxygen probe signal malfunction
* Intermittent malfunction, cylinder overburning disorder
4 original spark plugs were installed and a test coil was installed (& nbsp; purpose & nbsp; is the problem coil or not) also said the upper oxygen probe is defective, the room will change and sub-industry has installed delphi brand oxygen sensor
Spark plugs original 70 tl & nbsp;
Coil Trial Stuck
Upper oxygen sensor delphi & nbsp; 165 tl & nbsp;
Workmanship 60 tl & nbsp;
TOTAL 295 tl
< br>
CONCLUSION: & nbsp; I used it on the 1st day without any stop stop event I did not have a problem of motor swinging or traction in the A event, there was only a small hum at idle, only the air temperature was 17 degrees on the 2nd day. com / forum_posts.asp? TID = 45470 & amp; title = antipolluti o n-fault "rel =" nofollow "> Antipollution fault .. & nbsp; gave the damn error and the idle was broken, hurt, picked up and still humming not giving this error in cold weather. And whatever happens in this 80 degree heat is the temperature I came to. There is humming in an interesting idle, it sounds like an empty plastic box is shaking.
Apparently, the spark plug coil does not cause oxygen sensor problem.
what are your ideas. & nbsp;
& nbsp;
08.05.2020 20:44 # 8
Peugeot35
After all, this is the answer, since it is a vti engine, it does not like lpg. the problem is level up to 80 degrees, when it stops, a certain amount of vehicles give gas to itself. You can leave my paths. & nbsp;
08.05.2020 20:44 # 9
boruc
Is there a VTI engine in the 307s
08.05.2020 20:44 # 10
Peugeot35
[QUOTE = boruc] Is there a VTI engine in the 307s [/ QUOTE]
< div> means it doesn't have lpg engine & nbsp; "Ermm" & nbsp; I do not think that it is from lpg, we used it for 6 months without any problems.
08.05.2020 20:44 # 11
HasGur
If there is no abnormality in your LPG system, the source of your distress is most likely valves. If the exhaust misses the valve, the pressure on the piston turns towards the exhaust, the oxygen sensor produces rich mixture information when the combustion is not complete, BSI assumes that the spark plug is ignited etc. etc. and the failure of an electronic part such as a flow meter or the inability of a mechanical part like a butterfly to complete its task becomes undetectable.
Meanwhile, those who use LPG In order not to have any problems as soon as the symptoms that have been encountered and experienced with similar problems occur, & nbsp; Honors, volkswagens & nbsp; There.
08.05.2020 20:44 # 12
talip206
[QUOTE = HasGur] If there is no abnormality in your LPG system, the source of your distress is most likely valves.
The electronic control system accepts that the mechanics is working correctly and generates a malfunction code accordingly. If the exhaust misses the valve, the pressure on the piston turns towards the exhaust, the oxygen sensor produces rich mixture information when the combustion is not complete, BSI assumes that the spark plug is ignited etc. etc. The failure becomes undetectable when an electronic component such as a flow meter fails or a mechanical part such as a butterfly fails to function properly.
In the meantime, there are honda, volkswagen, who use LPG and have a valve adjustment of 5-10 thousand km in order not to have any trouble as soon as the symptoms that have encountered and experienced problems similar to those in your vehicle appear.
Yes, the friend has a lpg honda city, he constantly makes valve adjustments
08.05.2020 20:44 # 13
Peugeot35
It is true, teacher, but my problem is as follows; no problem since it was cold in the first run, I saw the car heat, the balance deteriorates when I stop at 70-80s, so there is no problem after a light plastic box jingling at idle and idle for one time, so it is not possible to get an idle especially in the heat, you will not understand once again. sometimes it is as if there is no problem, sometimes it is private pug serv. As it was said, the car does not go, my car goes up to 175s. There was a reason for my fuel consumption to increase, the problem was 1.2 clio spark plug caused by spark plugs. The particle was writing reno no said it was the same as the original one. After 3 months, it gave ignition error. Now, I changed it with the original one. is the problem I am talking about. ins solved someday i don't want to leave 307. Let's see now. Peugeot35 2018-02-11 13:43:17
08.05.2020 20:44 # 14
fatihyesilyurt
my 206 1.4 8v car has idle ripple. I usually don't care much about traveling between 800 and 900 cycles. stopping at idle in gasoline, collecting some gas, gathering 5 The same after 10 seconds. but there is no problem with gas. If I turn it on in the air conditioner, the resistance of the headlights does not stop if I turn them all on. I'm shifting gears by doing heel and to gasoline so that it doesn't stop from fear :)
08.05.2020 20:44 # 15
Peugeot35
[QUOTE = fatihyeşilyurt] my 206 1.4 8v car has an idle ripple. I usually don't care much about traveling between 800 and 900 cycles. stopping at idle in gasoline, collecting some gas, gathering 5 The same after 10 seconds. but there is no problem with gas. If I turn it on in the air conditioner, the resistance of the headlights does not stop if I turn them all on. I'm shifting down by doing heel and to gasoline so that it doesn't stop from fear:) [/ QUOTE]
I turn on the boiler, the temperature is fixed in the 70s, no problem :) I'm afraid 80 whatever it is, press the gas, the headlights dim, 4 lights closer, the torpedo lamp turns on, there are abnormalities such as this. will say click :)
08.05.2020 20:44 # 16
emretprmz
My teacher, look at the map sensor and the clutch switch. I got rid of my problems such as flickering and idling at the start by removing the map sensor and cleaning it. An oil-free spray works. Like a pad or contact spray. emretprmz 2018-02-12 23:34:28
08.05.2020 20:44 # 17
Peugeot35
Friends said that the engine oil was changed and you solved the problem, you said, what happened after the maintenance time, and the 10/40 oil left on the engine turned the car upside down and left 3 liters on top of it. 5/40 oil was the original oil of my 307 xr and I left this oil today, it is not clear whether the car was running idle or humming. So thank God the problem is solved.
The next problem is that the reason for the occasion is that when you pull the dipstick, there is no blowing, but when the oil is opened, they said that there is a little bit of steam blowing in the form of burning oil. my hp vehicle has 88hp performance, but there is light steam blowing from the place where the oil is placed. Is this the case? Or did I have my oil reduction at 5 thousand km or 700ml or something? Peugeot35 2018-02-15 21:40:12
08.05.2020 20:44 # 18
fatihyesilyurt
The devices that measure the horsepower of my teacher do not give very healthy results. as a matter of fact, even if we assume that it is correct, a difference of 2 hp cannot be interpreted as a sign of a malfunction. I am curious about the comments of friends who are experienced in oil reduction. We have been riding my father's 96 hawins for 12 years, and even that does not decrease any fat.
08.05.2020 20:44 # 19
HasGur
[QUOTE = Peugeot35] Friends said that you will change the engine oil and solve the problem. It happened after the maintenance time, and the 10/40 oil left on the engine turned upside down and left 3 liters on top of it. 5/40 oil was the original oil of my 307 xr and I left this oil today, it is not clear whether the car was running idle or humming. So thank God the problem is solved.
The next problem is that the reason for the occasion is that when you pull the dipstick, there is no blowing, but when the oil is opened, they said that there is a little bit of steam blowing in the form of burning oil. my hp vehicle has 88hp performance, but there is light steam blowing from the place where the oil is placed. Is that the case?
Get well soon,
When low fuel consumption change is ignored Difference between 5W-40 and 10W-40 at cold ambient temperature of -20 degrees during cold engine start If you are a good observer, you can feel that there is no difference in the oils you use to cause / resolve the problems you mentioned. If your problem is definitely resolved, it may be due to the fact that the situation that caused the problems in the previous oil change to be corrected consciously or unconsciously by the master who understands the error when the oil is changed again.
The maximum power of the 1.4 gasoline engine in your vehicle is 88hp at 5250 revolutions per minute (max speed is 172 km / h), although it is considered to be within normal limits until half a liter of oil is reduced at 1000 km, the less is the better and continues even in small amounts between the level controls. there should be no increase.
If DYNO testers are correctly calibrated, error-free results can be obtained, but the easiest, cheapest and accurate result for detecting the engine condition (not valid in all cases, the cheap engine with a cheap way to dispose of the vehicle and a thick engine with thick oil gives good results for a while) The way to take is compression test.
In top eccentric motors, light blowing and oil splashes are normal from the oil fill cap.
08.05.2020 20:44 # 20
Orcun.Dmr
Every overhead camshaft blows out of the oil cap and, as far as I know, in diesel Peugeots, it sounds like it comes out due to the mechanism of the thrusters (as in my vehicle). Smile
Page : / 2
