|   | Finally I was able to fix the Km screen. I am so happy :) |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 17:28 | # 1 |
|  Guests | |
|  Tachometer was broken. I had removed the instrument panel to fix it, but after fixing and replacing the rev counter, I noticed that the display with the odometer was not working. Whatever I did I couldn't fix it. It was not even though I placed the display tape properly. I went out this morning and ripped it off again and realized that the display bulb is not lit. Since the handbrake bulb did not work for me, I disassembled it and attached it to the screen and my problem was improved :) I got rid of giving money to the repairmen. I'm happy. I wanted to share. & Nbsp;  | |
| 08.05.2020 17:28 | # 2 |
|  yusufcaglarakarsu | |
Health in their hands & nbsp;  | |
| 08.05.2020 17:28 | # 3 |
|  zgr | |
[QUOTE = hLL 206]   Tachometer was broken. I had removed the instrument panel to fix it, but after fixing and replacing the rev counter, I noticed that the display with the odometer was not working. Whatever I did I couldn't fix it. It was not even though I placed the display tape properly. I went out this morning and ripped it off again and realized that the display bulb is not lit. Since the handbrake bulb did not work for me, I disassembled it and attached it to the screen and my problem was improved :) I got rid of giving money to the repairmen. I'm happy. I wanted to share. & Nbsp;   lone handbrake lamp only hand As far as I know it does not burn when the brake is applied & nbsp; there is a problem in the brake system. If such a problem happens, you will be unaware. If the bulbs on the dashboard were not mistaken for 1.2 w, then I wish you could wear them. or you would get off the fog lights.
| 08.05.2020 17:28 | # 4 |
|  bysarsinti | |
master, I repaired it in the same way, the wheel of the engine was broken, I took care of it, I put it all in now, the temperature and the fuel hand went up completely, it did not cause you to die.
| 08.05.2020 17:28 | # 5 |
|  Guests | |
| [QUOTE = bysarsşı] master, I repaired it in the same way, the wheel of his motor was broken, I took care of it, I put it all up, now the temperature and the fuel hand went up, it was completely up and you didn't have a problem. [/ QUOTE]< p> I do not have such a problem. you can disassemble it and lower them by hand. wear it like that? | |
| 08.05.2020 17:28 | # 6 |
|  Guests | |
[QUOTE = zgr] [QUOTE = hLL 206]   Tachometer was broken. I had removed the instrument panel to fix it, but after fixing and replacing the rev counter, I noticed that the display with the odometer was not working. Whatever I did I couldn't fix it. It was not even though I placed the display tape properly. I went out this morning and ripped it off again and realized that the display bulb is not lit. Since the handbrake bulb did not work for me, I disassembled it and attached it to the screen and my problem was improved :) I got rid of giving money to the repairmen. I'm happy. I wanted to share. & Nbsp;   lone handbrake lamp only hand As far as I know it does not burn when the brake is applied & nbsp; there is a problem in the brake system. If such a problem happens, you will be unaware. If the bulbs on the dashboard were not mistaken for 1.2 w, then I wish you could wear them. or if you disassemble the fog lights. I will get it as soon as possible if I find it.
| 08.05.2020 17:28 | # 7 |
|  Guests | |
[QUOTE = zgr] [QUOTE = hLL 206]   Tachometer was broken. I had removed the instrument panel to fix it, but after fixing and replacing the rev counter, I noticed that the display with the odometer was not working. Whatever I did I couldn't fix it. It was not even though I placed the display tape properly. I went out this morning and ripped it off again and realized that the display bulb is not lit. Since the handbrake bulb did not work for me, I disassembled it and attached it to the screen and my problem was improved :) I got rid of giving money to the repairmen. I'm happy. I wanted to share. & Nbsp;   lone handbrake lamp only hand As far as I know it does not burn when the brake is applied & nbsp; there is a problem in the brake system. If such a problem happens, you will be unaware. If the bulbs on the dashboard were not mistaken for 1.2 w, then I wish you could wear them. or fog lights.  [/ QUOTE] Based on your advice today, I took and replaced the bottomless bulbs of 1.2w. After all, security is important. Thank you. P> | |
| 08.05.2020 17:28 | # 8 |
|  zgr | |
[QUOTE = hLL 206] [QUOTE = zgr] [QUOTE = hLL 206]   Tachometer was broken. I had removed the instrument panel to fix it, but after fixing and replacing the rev counter, I noticed that the display with the odometer was not working. Whatever I did I couldn't fix it. It was not even though I placed the display tape properly. I went out this morning and ripped it off again and realized that the display bulb is not lit. Since the handbrake bulb did not work for me, I disassembled it and attached it to the screen and my problem was improved :) I got rid of giving money to the repairmen. I'm happy. I wanted to share. & Nbsp;   lone handbrake lamp only hand As far as I know it does not burn when the brake is applied & nbsp; there is a problem in the brake system. If such a problem happens, you will be unaware. If the bulbs on the dashboard were not mistaken for 1.2 w, then I wish you could wear them. or fog lights.  [/ QUOTE] Based on your advice today, I took and replaced the bottomless bulbs of 1.2w. After all, security is important. Thank you.[/ QUOTE] You're welcome . As you said, security is important. good bye.  | |
