Finally I got lpg installed
08.05.2020 15:38 # 1
tarkankarabas
As of yesterday, I had the LPG at the place recommended by our cem brother. atiker fast brand kit was installed. friends were very interested. We had minor problems, but the results are good for now. The regulator that was installed was out of order. Also, the cable that started the PC on the car was broken or something :)) the tank was mounted under the car as a bagel and was comfortable to see the protection armor. the tank is already strong, the armor is solid from it. I hope there won't be a problem. I returned home from there after the highway ... I certainly did not feel the slightest loss of traction compared to gasoline. he was just making a sound when putting him in reverse. he also slipped the exhaust on the ground and left the engine. When the engine in forward gear goes forward, it is intermittent. Now he's done like a cillop when he handled 20 tlies. we have not noticed before. We couldn't force the engine so that we could save :)
I didn't really calculate fuel consumption, but first impressions seem to be fine. If I am fortunate that I will go long on Sunday. on the way I calculate the fuel consumption 3 or 5 up.
If anyone thinks and hesitates to have it installed, I think that it will never happen. km `at least 10 - 12 kr. makes the difference. I try to share the negativity or beauty that may occur as I use it from here.
the cecol 2011-06-16 15:39:10
08.05.2020 15:38 # 2
Come on, use your eyes bright ... bye ...
08.05.2020 15:38 # 3
I hope you have a problem.
08.05.2020 15:38 # 4
tarkankarabas
Thank you, teacher.
By the way, I forgot to write in the first message. thank you to cem. Thank you very much. even coincidence itself fell to the same place. so we met personally. :)
08.05.2020 15:38 # 5
anil307
good luck
08.05.2020 15:38 # 6
metin
Come on, use bye.
08.05.2020 15:38 # 7
Good luck, we burn days
08.05.2020 15:38 # 8
Best wishes. smooth, accident-free miles.
08.05.2020 15:38 # 9
Good luck my brother Tarkan ... I wish you to use Gule gule.
Dun Masl * ga thought, I thought you were there, I said you should be good :)) We got to know ...
If it was necessary to speak openly about the regulator, the first regulator, which was attached to me, changed 2 months later when I realized that it was malfunctioning. There was no more trouble afterwards. So this kind of trouble has come across you. I haven't heard of any other hiccups anyway ...
The service is like I eat myself. Thank you, they are all concerned. I wish you were satisfied. You can share the machine room and warehouse pictures with us at the appropriate time ...
In the meantime, I made a little correction to your first message and added the fast word as the model of the wasteer.
the cecol 2011-06-16 15:40:29
08.05.2020 15:38 # 10
___KxL___
good luck
08.05.2020 15:38 # 11
dinoco
goodbye with your loved ones, use it with the taste of agaz, my friend
08.05.2020 15:38 # 12
cetin
Sister, good luck, they told me to the atiker service that I took yesterday, but they said that it would not be good for me to wear it at the bottom. our fuel savings accounts amount the rest story Göz Kırpma
08.05.2020 15:38 # 13
Best wishes. I wish accident-free and economical driving.
08.05.2020 15:38 # 14
tarkankarabas
thank you all for your good wishes. I think the distance to the ground was quite enough because there was no drop in my vehicle. it also remains on the exhaust when the tank is installed. they put the small tank in the trunk and it really takes up a lot of space :(
08.05.2020 15:38 # 15
Haksen016
good luck use it, we look forward to its values.
08.05.2020 15:38 # 16
mdincer34
LPG is very economical on the long road. I was very happy with it in my previous car.
08.05.2020 15:38 # 17
mon
you made the best one, you can go 12 14 km with an estimated 1 liter of gas
08.05.2020 15:38 # 18
sertacizm34
What is the average cost of having maloluyo lpg? I have one end of my mind, but we have not dared yet.
08.05.2020 15:38 # 19
[QUOTE] I decided to get it installed. Göz Kırpma [/ QUOTE]
There is no such thing as approaching the ground. The height of the vehicle is sufficient. In addition, the reason for the fact that they do not want to install tanks at the bottom is because they have more ugra. Otherwise, it does not create any problems ... But it can not be used in lowered vehicles. Because the height must be at least 20 cm above the ground.
08.05.2020 15:38 # 20
tarkankarabas
Installing LPG depends on the brand of the kit to be fitted and the model of the vehicle. Atiker fast kit was installed in my vehicle and kept 1100 TL including bagel tank. however, it would be 990 TL if it was a normal tank. It will also hold about 250 TL of licenses. I immediately received the invoice and the project that I intend to run next week. I am running it immediately after the 25th.
I also had 94 spring vehicles. Although it was a really old and flat system kit, it was very economical.
Page : / 3
