Finally I Got It :)
08.05.2020 17:30 # 1
Feyribas
URL = http: //imageshack.us/photo/my-images/545/imagerrw.jpg/] [/ URL]
08.05.2020 17:30 # 2
Goodbye use "Thumbs & nbsp; It was a solid installation, but the height of those on the rear window side came to me a lot
08.05.2020 17:30 # 3
Feyribas
[QUOTE = hLL 206] Goodbye "Thumbs It has a solid installation but the height of the rear window side is very high it came to me [/ QUOTE]
The original flooring was not harmed at all and was placed on the rear pendulum. When it is available, it can be removed by removing the clips. My only problem is to leave everything originally in the original car ... :)
08.05.2020 17:30 # 4
[QUOTE = Feyribas] [QUOTE = hLL 206] Goodbye "Thumbs & nbsp; It was a solid installation but Aesthetically, the height of those on the rear window side came to me [/ QUOTE]
The original flooring was not harmed at all and was placed on the rear pendulum. When it is available, it can be removed by removing the clips. My only problem is to leave everything originally in the original car ...:) [/ QUOTE]
You thought well. I like the original. By the way, how much does it cost? Although it is not that professional, I want it too & nbsp; "Approve"
08.05.2020 17:30 # 5
hsnsnl
finally you put me in the yaw set to the car :) dear cekıyo bole gorunce 407s .. did you take the inputs of the tape recorder with the translator? after that you can already help: D .. Have you also examined the presentation of the original jblin 407 have an amp and bass .. If you enter the service box in the right side, you can see from there .. Press the valve and I wonder how it improves the sound that is used by the anfi assembly. I have & nbsp; 2 sets of components, 1 double amphitheater, but I can not break the vehicle to break the car.
08.05.2020 17:30 # 6
serkan719
booms Hullo..
08.05.2020 17:30 # 7
Bugra
very bad too
08.05.2020 17:30 # 8
Feyribas
[QUOTE = hLL 206] [QUOTE = Feyribas] [QUOTE = hLL 206] Goodbye "Thumbs & nbsp; It was a solid installation, but the height of those on the back side of the aesthetic point came to me [/ QUOTE]
< br>
Well my teacher, this installation is only electronic products around 2.500 TL It cost 200 TL as a custom made in the cabins and cabinets and 100 TL in the cables and accessories ...
08.05.2020 17:30 # 9
Feyribas
[QUOTE = hsnsnl] will you put me at the end of the yaw set to the car :) dear cekıyo bole gorunce 407 .. Did you take the inputs of the speaker with the translator in the tape outputs? after that you can already help: D .. Have you also examined the presentation of the original jblin 407 have an amp and bass .. If you enter the service box in the right side, you can see from there .. Press the valve and I wonder how it improves the sound that is used by the anfi assembly. I have & nbsp; 2 sets of components, 1 double and 1 amp. I shared this forum also in the Deck Converter Title. I even thought to get the original tape from the inside of the upgrade floor. then I used Osewa deck translation, I didn't experience any difference in sound quality. So it's not like the original Pioneer alpine, but the sound quality has not decreased. Also, Pioneer has 4350 Doubes. I could not use it. I used the trigger cable of the CD changer output behind the tape as the trigger tip. Their original hop also plays number 10 ... But I burned the trebles in front. :( If you have 407, never break the original ...
08.05.2020 17:30 # 10
Feyribas
[QUOTE = serkan719] is booming. thank you .. [/ QUOTE]
Thank you bro ... :)
08.05.2020 17:30 # 11
Feyribas
[QUOTE = 307bursa] wow, use it on a good day, the installation is very solid & nbsp; [/ QUOTE]
Thank you ...
08.05.2020 17:30 # 12
_PunisheR_
It satisfies quite a lot of it in the trunk, it was cooled from 206 sedan I miss the car so "LOL"
08.05.2020 17:30 # 13
samet206
Good installation, good luck :) By the way, I wanted to use the original tape.
08.05.2020 17:30 # 14
emre_akdag
very good maşallah .. god do not give zeval :)
08.05.2020 17:30 # 15
Feyribas
[QUOTE = samet206] good installation good luck :) By the way, I wanted to use the original tape, I guess what if I did not remember it wrong? Yes, I used the original tape and I have no problem ... :)
08.05.2020 17:30 # 16
Feyribas
[QUOTE = toretto16] very good, maallah .. don't give it to Allah:) [/ QUOTE]
God bless ...
08.05.2020 17:30 # 17
Burak
I couldn't see the tape but how did it work :)
08.05.2020 17:30 # 18
Feyribas
[QUOTE = Burak044] I couldn't see the tape but how did it work :) [/ QUOTE] When I say tape? I used the original tape.
08.05.2020 17:30 # 19
elsoberano
use very badly bye.
08.05.2020 17:30 # 20
acemi pecocu
In my 2005 model, I can't find a cassette to play a tape. car cassette player now "LOL"
Page : / 2
