Filter kit selection help
08.05.2020 16:40 # 1
GiTaRRa
the filter in my friends tool is finished and fed up now :)
now I am waiting for your help, which filter kit should I use, the simota everyone is using different increase Does anyone provide?
08.05.2020 16:40 # 2
hsnsnl
K & N in-box or open
08.05.2020 16:40 # 3
EmSul
Friends urgent help, I said not to open a new topic. Does the 307 exhaust air filter kit fit my 206 GTI? So the pipe inlet diameter of the air filter kit is the same as 307 and 206 GTI or is it different? If you answer an urgent answer, I will buy accordingly. If not, I will buy one simota carbon filter and one pipe that fits GTI, but if the pipe from 307 fits, it will be cheaper. What should be 70mm or so?
08.05.2020 16:40 # 4
sercinho
[QUOTE = sümubofnsb "emrah"] Friends urgent help I said not to open a new topic Does the 307 air filter kit fit my 206 GTI? So the pipe inlet diameter of the air filter kit is the same as 307 and 206 GTI or is it different? If you answer an urgent answer, I will buy accordingly. If not, I will buy one simota carbon filter and one pipe that fits GTI, but if the pipe from 307 fits, it will be cheaper. What should be 70mm or so? [/ QUOTE]
pipe fits as much as i know the outlet mouths should be the same
08.05.2020 16:40 # 5
EmSul
So how many mm is it?
08.05.2020 16:40 # 6
EmSul
Can I also use the pipe of the filter kit that fits 307 with 206 GTI? Where are the masters of this site :)
08.05.2020 16:40 # 7
metin
I recommend Green open air filter. I am very happy to use it in my own vehicle. It is idle in my hand because it sells my vehicle. In calm use, the fuel fell, and the performance of the vehicle increased significantly.
