filter a particul (FAP) cancellation
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 16:36 # 1
cerci07
how are we doing together we can cancel the filter a particul (FAP) or diesel particul filter (DPF) how to cancel it, but the subject is quite complicated and requires a skill to make, first we need the materials and the method we need to follow 1 mpps or galetto flasher aracin ecu You can find 2 ecusafe programs that are necessary for us to read and rewrite the presentations on the internet. We call id (f1), save the numbers on the top right of the screen, then we read read (f2) after reading the file, we need to turn off the contact and wait for 3 minutes and then copy the dump to a new one of the pc that we want, copy it twice, start one, keep the original one, download it to the ecusfe that we downloaded from the pc before If you want, I have the model of the vehicle) We say open binary, we select the dump that we copied from the ecu and if we say save binary, if everything is normal, we reprint the dump again with mpps. If you do not have pp2000, please ask a mechanic if they did not make a mistake in the middle of the fap, if you did not make a mistake in the middle of the fap, you will have to open a big hole in the middle of it like this By mustafacerci at 2012-02-22 17
08.05.2020 16:36 # 2
kaan__
What is the purpose for such a transaction? Why did you want to cancel it
08.05.2020 16:36 # 3
cerci07
the goal is to change this filter to 800 € The price of the substance put on the cleaning tray is 100 thousand km per liter. it has 4 liters of storage and ends every 60 thousand + the car is extremely heavy
08.05.2020 16:36 # 4
Halal. It was a very nice work. This FAP hardly probable probably could not begin to press agritur in Turkey. Reading the nation's life in Europe & nbsp; "Smile"
08.05.2020 16:36 # 5
nupel307
tskler guys for your work..what makes a difference in fuel if we do this process, and how many a good master does it .. tşkler
08.05.2020 16:36 # 6
nupel307
08.05.2020 16:36 # 7
cerci07
Wait for the filter to be filled a lot to do this process. When the filter is new, it does not matter, when the temperature starts to fill up, the fan will run even if the temperature is regenerated, even if the temperature is 70-80, the fan starts and the fuel consumption from 5L to 8-9Ls is the most this time. At the same time, 5.3L went up to 8L100km on the same road I did with 100km
two years ago 800 € I changed it again filled the cost of canceling 50 € mpps flasher & nbsp; bought 50 € pp2000 Price Price is the biggest mechanical repairers gave my master
I do not know the prices of turkey, but here 200 € electronic 200 € they take for mechanical cancellation
08.05.2020 16:36 # 8
cerci07
[QUOTE = Koliva] Halal. It was a very nice work. This FAP hardly probable probably could not begin to press agritur in Turkey. Reading the nation's life in Europe & nbsp; "Smile" [/ QUOTE]
thank you too to basagrit & nbsp; & nbsp; We started trying to be aspirin for those who have courage. There are places in the country that cancel, but we do not share some things here.
08.05.2020 16:36 # 9
djchaos
There are people who cancel the floor for performance, or those who cancel the floor after starting to break down, after the floor is canceled, some of them connect flat pipes.
08.05.2020 16:36 # 10
kaan__
did not know
kaan__ 2013-01-18 17:07:52
08.05.2020 16:36 # 11
cerci07
Assuming that it is almost impossible for the captured fap to fall off spontaneously while on the road, it may have changed the previous owner from you if you bought the 100% malfunction lamp light tool or canceled it in one of the repairman you left or not in the factory.
filter price is between 1000-2000tl, depending on the model, reloading of the additive warehouse or software, it costs a lot of workmanship, fuel definitely increases, at first, not too much, it increases in later times
08.05.2020 16:36 # 12
kaan__
& Nbsp; kaan__ 2012-06-03 15:30:09
08.05.2020 16:36 # 13
cerci07
[QUOTE = kaan __] the car is not yet going to go from service to 30.bin anyway .... any other cancellation can not be in question .... I am already in favor of adding the additive again ... but when I get it, will it work? I do not know ... the malfunction lamp did not light up in the service for now, but it was said that the additive will be activated because there is no contamination at all ... it will be possible that some time will pass, but ... I was confused when you said so, & nbsp; [/ QUOTE]
it is easier to understand the subject with a little bit of pain.
knows whether the captor filter is full at the entrance and exit of a different version of the fap catalyst, and the sensor knows whether the filter is full or not. It sends to the pump, mixes with diesel and sends it to the engine. It is necessary to use it until the end of the process. Some of the features are notified to the driver with the warning lamp started by the regeneration. There is no such feature in these vehicles. ozell Not only the filter gets clogged & nbsp; and the cost is as high as I mentioned above.
I think if you want to re-install the system, you're looking for trouble without worry.
08.05.2020 16:36 # 14
kaan__
What is a particulate additive, I will investigate a little more! kaan__ 2013-01-18 17:09:33
08.05.2020 16:36 # 15
cerci07
Normally there is a probe with the EOLYS level, and below the specific level, you will see the error message on the screen. Normally, it must be in the dust at the moment, it is not easy to fall, you may be mixing it, it may not be just below the diesel tank. It is not necessary to drive 80-100km daily with fap vehicle, otherwise the malfunction lamp will light up frequently.
08.05.2020 16:36 # 16
FAP models which have in Turkey? Member Mr. Are you sure the FAP slot in your vehicle? If there is no FAP, it is normal that there is no additive. Maybe I'm asking you don't have it in your car.
One second. cerci07, you have to lift your car to do this work in your garage in France. This is I couldn't find a solution here. So for example, I need to change the exhaust right now, but I could not provide a safe environment where I can remove a vehicle. There is a jack, there are two elbows, but still not. How are you doing this job?
koliva 2012-02-22 06:30:08
08.05.2020 16:36 # 17
cerci07
[QUOTE = Koliva] FAP which models have in Turkey? Sec. Are you sure the FAP slot in your vehicle? If there is no FAP, it is normal that there is no additive. Maybe I'm asking you don't have it in your car. cerci07, you have to lift your car to do this work in your garage in France. This is I couldn't find a solution here. So for example, I need to change the exhaust right now, but I could not provide a safe environment where I can remove a vehicle. There is a jack, there are two elbows, but still not. How do you do this heat? [/ QUOTE] Since my vehicle is 1.6 hdi, I can only remove the front part on the bottom of the fap ten. de mustafacerci at 2012-02-22 I removed the ten parts of the vehicle and inserted the captor pipes in the fap in the middle section where there was one radiator, then I inserted the clamp on the lower part By mustafacerci at 2012-02-22 By mustafacerci at 2012-02-22 -22By mustafacerci at 2012-02-22 I did not remove it for him because the small engine is big, it is very difficult to remove the protection, I have removed the middle clamp that holds the protection lightly, and after removing the middle clamp that holds the fap, there are the titanic rivets that pull them out with the screw, the wrench pulls the filter right downwards. at 2012-02-22 By mustafacerci at 2012-02-22 By mustafacerci at 2012-02-22 and then a small hole in a 5-6cm diameter drill I hope I collected it again in the same way, I hope the parts I leave will not click on the copy in the future. If it breaks, it will make a sound. By mustafacerci at 2012-02-22 cerci072012-02-22 10:48:31
08.05.2020 16:36 # 18
kaan__
kaan__ 2012-06-03 15:32:10
08.05.2020 16:36 # 19
cerci07
Have you ever encountered a & nbsp; fault message on your vehicle before?
I have read in another forum that there are brands that use pure fap & nbsp; before, but peugeot is not among these brands.
I was amazed like you, what will happen if we wait and see this situation
08.05.2020 16:36 # 20
Have you ever changed the exhaust Cerci07?
Page : / 2
