fever-help please
08.05.2020 14:16 # 1
ozaannn
I had a heat problem for the sake of my friends, for the sake of God, I shared it recently. There is no room, in fact, this shows that there is no heat at the same time, but the indicator goes up to 110. If you force yourself in the city, until 120. If you say I am in the car, the car will overheat. I HAVE TO KNOW THAT I KNOW I KNOW MY CAR HOWEVER, BUT SIRF I WAS SOLD OUT FOR SALE BECAUSE I DON'T FIND A SOLUTION PLEASE HELP
let's 2010-06-13 11:09:18
08.05.2020 14:16 # 2
Eleanor_
the same problem you say happens in me, sometimes even when the temperature turns out to be the highest red. If you find the problem and share it, I will be very happy. I guess that the vehicle 206 !!
08.05.2020 14:16 # 3
BuRCaK
I did not see until red, but I saw 110 in my car 25000 km more. In traffic, the fan is always on. These engines are the same as the C4 engine, and when I had 1.6 C4, I had no movement problems. I wonder if this problem has 1.4 engines? I had no problems on 1.6 of the same engine because?
08.05.2020 14:16 # 4
mabolla
the other day, the heat ceiling in the city and the screen gave an audible warning with a text such as "engine temperature is too high", the water was also full, so it was impossible to heat it, I thought of the heat, because the heat was suddenly pans. But I did not care much. Somehow I went to the service somehow, my master understood the problem immediately, the fan was not engaged, we changed the fan sensor and the temperature sensor in 10 minutes, the whole issue was solved ... I gave 10 TL to pieces for 10 TL to workmanship.
I guess that's why your problem stems from it ..
08.05.2020 14:16 # 5
BuRCaK
In 206's the fan turns on at 97 degrees. There is no problem opening up in my fan. it starts to descend with the fan. but no car in the market is moving so quickly, why don't we understand this problem in the 206's.
08.05.2020 14:16 # 6
mabolla
I do not think that there is a problem with the engine in your vehicles, cars that were in traffic from morning to evening, or my housemate has also had 206 such problems so far, I do not think that there is a very important problem, that is, until your friend put the car on sale. Did you go to a qualified service?
what do they say
08.05.2020 14:16 # 7
behzat
My brother, the engine is weak, the engine is running very fast, I asked the service and he said the same thing.
08.05.2020 14:16 # 8
mabolla
The engine in the pugs is the engine of the PSA group. It uses this engine in many vehicles of peugeot, citroen, ford, volvo. and it is a very successful engine.
08.05.2020 14:16 # 9
Onur
[QUOTE = behzat] brother, the engine is weak at these peugeot, the engine is overheated. I asked the service and he said the same thing. Toyota engine was used in the new peugeot. The problem has been solved. No matter how much you get stuck, it is not a weak engine. Peugeot engine runs hot compared to other engines.
08.05.2020 14:16 # 10
Onur
[QUOTE = ozaannn] Friends I had a heat problem for the sake of god, I shared it recently. There is no room that makes you sprinkling from the ground or even the atrium. It shows that there is no temperature at the same time, but the indicator goes up to 110. If you force the city up to 120. If I say I am in the car, the car will heat up immediately, it will boil water. I HAVE SOMEONE WHO KNOW WHY I HAVE KNOWED THAT THE PROBLEM I LIKE MY CAR LIKE BUT SIRF I WAS SOLD OUT FOR SALE, PLEASE I DON'T FIND THE SOLUTION
[/ QUOTE] Check the fan sensor, let the tool connect to the PC, control the thermostat, if the car is 206, there is 89 thermostat at the base, so if the temperature does not decrease, ask 83 the thermostat.
08.05.2020 14:16 # 11
ozaannn
Arcım 2000 model xt 1,6 8 v. kmsi 100000 we did not use any of the car, I did not understand any car, I guess there is no one who has full detailed information.
08.05.2020 14:16 # 12
ozaannn
Guys, now I have a sense that I did not maintain the vehicle for 10000 km, but since there is no more than 500 km of time, someone said, change the spark plugs.
08.05.2020 14:16 # 13
Long Beach
There is a guarantee, go to the service and have care for your problem.
The first and only pug. It is not you who use it, if there is a problem, there is a solution.
Peugeot engines are a successful machine.
In the service that says Peugeot engine is weak, I think it will pass to another brand.
To say bad things that they cannot do and understand, those who do not know and who are not capable of learning
kacis carey. Have oil-filter and other maintenance done on time, at least 300.000km in the same
you use the engine.
08.05.2020 14:16 # 14
Melih
I agree to friend yet never BORING 323000 km 1999 model also uses the 1.4 x Toyota factory worker saw the vehicle pass bi aracı.peugeot received only 99 when the Japanese came to my turkey
08.05.2020 14:16 # 15
bulent 77
These kinds of problems arise from the fan sender.
08.05.2020 14:16 # 16
BAHTIYAR
Even when I pushed it too hard, it went over 90. I think the engine is successful.
08.05.2020 14:16 # 17
FTH
Get well soon..
The subject has been moved to the part that should be.
08.05.2020 14:16 # 18
deniz_206
Yes, 206 engines get hot and heat rises even at a very short distance, it takes a lot of time to cool down after stopping the vehicle.
08.05.2020 14:16 # 19
Hello ,
3 months ago, 93 model 106 xr, I bought my single door car.
I am a stranger to the car because I was driving a peugeot for the first time.
The question I want to ask is no temperature indicator in my 93 model car.
If this vehicle doesn't say much heat; Can I say option options in those years?
Lamp replacement instead of temperature indicator, I don't know how this system works.
How do I know if the car overheats for a particular reason?
I am waiting for your help in this matter. Thank you ...
08.05.2020 14:16 # 20
BAHTIYAR
[QUOTE = pejbıg]
Hello ,
[/ QUOTE] is already in action when the lamp is on, there is a hundai accent in my uncle. And it is not so.
Page : / 2
