Feeling of clutch leaking at high gears
08.05.2020 21:10 # 1
yaso0.53
Friends greet everyone; I would appreciate if there is any knowledge or legitimacy about the situation I am dealing with, and I would appreciate it.
Since my 2001 model peugeout 306 platinium was recently over, I had to change it since I was interested in the machine and mechanical work and decided to change the clutch set by myself. For this, I started by taking the car on the fiber by keeping my friend's shop busy by an evening. I renewed the clutch wire with the original one. I would also go through the periodic maintenance of the gearbox oil, such as engine oil, air filter, oil filter, and now the problem is my vehicle & nbsp; low-speed traction, without any trouble, the paw goes to the bay and the clutch is very soft Arasin also seemed to be a problem. It comes to the s, but the vehicle does not exceed 110 km, it feels like it is missing the pressure, but it does not go, the neighborhood Arasin says there is no problem in the traction, while a master says that the wire is missing, another says that I may have installed the pressure plate in reverse, and another says that there is no problem in the vehicle, but If you ask me, before changing the pressure of the vehicle, I was seeing a comfortable 170 180 km without shouting in 5th gear, but now I have to scream until I get the engine to reach those kms, what do you think is the problem?
08.05.2020 21:10 # 2
There may be a problem with your operation, brother. parts you do not wear, etc. You changed the bearing when changing the pressure. ?
08.05.2020 21:10 # 3
yaso0.53
Of course I bought it as a set, changed it on the ball, even when the transmission was down, I checked the clutch catal by hand, and everything was fine because there were gaps, etc.
08.05.2020 21:10 # 4
If a strange situation is a problem, it shows up in 1-2 gears. If you have time, I recommend you to remove and re-install the gearbox over the weekend. You can also control the lower and upper centers of the clutch.
08.05.2020 21:10 # 5
yaso0.53
Is there a clutch center in this vehicle, there was only one clutch wire, I am telling you to change the room myself, one end is the clutch latch (on top of the transmission) the other end is connected to the clutch pedal. Thank you inside.
08.05.2020 21:10 # 6
yaso0.53
Thanks to everyone, we solved the problem.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
