faulty antipollution peugeot 308 error
08.05.2020 20:28 # 1
Gorkem308
Hello friends,
My car was a 2008 model peugeot 308 petrol 1.6 vti. I bought the car 8 months ago and bought it by showing 2-3 masters while it was buying. For 1.5 months, the engine malfunction lamp is on, faulty antipollution error. The car falls out of traction. When we put it on, it gave ignition error, they said the spark plug 4 spark plug changed error went 15 minutes later I came to the front of the house again, the lamp burned and the engine started to shake.
I went, they said the coil, one of the bobbins was not working, we replaced it with zero, it cleared the error 15 minutes later, when I came to the house, it was the same again. While the engine is shaking like an aftershock, the engine lamp flashes and gives a faulty antipollution warning and starts the fan.
I mean, I don't know exactly what the problem is, if anyone with experience on this issue can help, thanks in advance.
08.05.2020 20:28 # 2
First of all, welcome to us. Do you have LPG in the vehicle, hodja? In general, such problems are caused by oxygen sensor - map sensor - gasoline filter - gas pump. Is there a situation such as water loss in the vehicle
08.05.2020 20:28 # 3
Gorkem308
Hello brother, thank you.
There is no LPG gasoline car, it does not reduce water, but there is a situation that I have encountered that I have encountered, usually when I park it or wait for the red light and wait for it to stop in Istanbul traffic, it suddenly fails and starts the fan and falls off the traction. .
08.05.2020 20:28 # 4
Görkem, I think, first of all, go to a service with original peugeot software, check the values of the vehicle and read one or more of the sensors to the error codes, which causes malfunction. It looks like an oxygen sensor, but you look for an error code, brother.
08.05.2020 20:28 # 5
CemDemiral
The same error was happening with me. The vehicle does not exceed 3000 rpm. It falls from the traction. The engine is shaking. Antipollition error means that it is caused by vehicle filters or filtering problems transmitted from the fuel. I made them to me. You have to go to the authorized service and look at this problem. This problem came back to me as a burst of turbo hose.
08.05.2020 20:28 # 6
adnanalbayrak
Master 307 also has a topic on the same fault. In the link, I explained the failure and the solution that I experienced for a long time. Link; https://forum.peugeotturkey.com/forum_posts.asp?TID=18913&title=antipollution-fault-cozumu ;
maybe it helps. Get well soon.
08.05.2020 20:28 # 7
Gorkem308
I would like to thank everyone for your help, Allah does not cause any trouble for our sentence, good work.
08.05.2020 20:28 # 8
Ufuk_64
I am following the forum like 6 months to everyone, I didn't register because I didn't like to correspond. My vehicle thp engine I drew a lot from this engine, in fact, the problems can be found simple, but even in the slightest problem (even whatever) the engine will open, etc. they make mistakes that can write their big invoices. What happened to me if I write 1 day is not enough. Judging by the mistake of the friend's vehicle and the reaction of the engine, it feels like a gas pump. Since my vehicle is a turbo, this part is referred to as a high pressure pump. Generally, in gasoline vehicles, this pump has its power (with double eccentric) from the rear eccentricity. But if you have any, please make sure to go and get a new one right away and do not trust neither service nor it. You have the same error as the engine and the reaction of the engine is the same as mine, there is nothing when the engine is going, neither traction nor anything, but when idling, it works like 2 pistons as if the engine came out of the hood. The engine is connected to the calm engine. I hope you find the malfunction easy. Note. There may be another malfunction, I commented on the reaction of the engine after the malfunction.
08.05.2020 20:28 # 9
Gorkem308
Salas, my brother, I have been trying to get on everyday for 3 weeks. Let's see what happens. Thanks for your help.
08.05.2020 20:28 # 10
[QUOTE = Ufuk_64] I am following the forum like 6 months to everyone. My vehicle thp engine I drew a lot from this engine, in fact, the problems can be found simple, but even in the slightest problem (even whatever) the engine will open, etc. they make mistakes that can write their big invoices. What happened to me if I write 1 day is not enough. Judging by the mistake of the friend's vehicle and the reaction of the engine, it feels like a gas pump. Since my vehicle is a turbo, this part is referred to as a high pressure pump. Generally, in gasoline vehicles, this pump has its power (with double eccentric) from the rear eccentricity. But if you have any, please make sure to go and get a new one right away and do not trust neither service nor it. You have the same error as the engine and the reaction of the engine is the same as mine, there is nothing when the engine is going, neither traction nor anything, but when idling, it works like 2 pistons as if the engine came out of the hood. The engine is connected to the calm engine. I hope you find the malfunction easy. Note. There may be another malfunction, I commented on the reaction of the engine after the malfunction. [/ QUOTE]
Thanks for the information, teacher
08.05.2020 20:28 # 11
Gorkem308
Friends, hello my sentence,
Anyone who knows a good master on the Kocaeli or Istanbul side?
Because no solution has been found in the car industry for 3 months, I went to the authorized service, the original computer was connected, the piece was tried from another car, but it did not happen again, I would be glad to go to another place, if anyone knows a good master, I would be glad.
08.05.2020 20:28 # 12
ismailkaya
Do the vehicles you use give a stop sign? Does it seem like the vehicle will stop when you turn on the road or when you turn on an electrical switch? or fluctuations in period? km of your vehicle. How many, have you changed your battery? or how many amps? Did you also have extra electrical equipment installed in this vehicle like an amphitheater? Have you ever washed your car's engine?
08.05.2020 20:28 # 13
Gorkem308
Hello there,
I did not wash the gasoline engine in 207 thousand km of the vehicle, when I turned on an electrical button, it did not stop, today, for example, I started the car, when the cycle was falling, the car shook quite a bit, I stepped on the gas twice, I did not eat it, then I turned off the ignition, I ran it again, the fan did not work, but it came down and came over to me, 1 min then I started driving the car, but the engine fault lamp was constantly on. I did not change the battery, there is no sound system. The car has changed a lot of parts in 2 months, the top engine was made, everything changed, 4 thousand costs occurred but the problem could not be solved, the authorized service gives the part in the original computer as I wrote above, the problem is the same, the last one is a master eccentric and eccentric he said it may seem like he said but it is not sure it was expensive at zero.
08.05.2020 20:28 # 14
Ziko
Glory,
Hello, I have read this article by chance. Have you got the same fault?
problem.
04.07.2021 10:24 # 15
Medeni
Hello, I have the same error today, faulty antipollution, out of nowhere, you did a research on the internet first, I didn't see what the exact solution is.
My car is Peugeot 308 2008 model 1.6 diesel, please help with this issue
04.07.2021 10:26 # 16
ismailkaya
Have catalyst and soot cleaning in diesels, catalyst upper and lower oxygen sensor cleaning.
05.07.2021 13:59 # 17
Monur11
It will sound ridiculous, but check the battery. If the battery is running out, it cannot feed the sensors properly. It gives the non-existent error. I have been dealing with this error for 1 year in my Peugeout 207 diesel vehicle. After replacing the battery, there was no problem.
