Faults in cold weather
08.05.2020 16:22 # 1
cetin
When the masters start to accelerate when cold, but not in hot weather, but in cold weather, the car suddenly slows down and the snow mode and sports mode sign are on. The vehicle gets to protect itself, it does not pass on the triptonge. Returns. Why is this problem caused by you & nbsp; "Questi
08.05.2020 16:22 # 2
tolga35
Did you try to warm the engine for a short time and try to start off because the fluidity of the oil decreases in the cold and it can be a problem ...
08.05.2020 16:22 # 3
cetin
Master, the speed rises after starting to accelerate, that is, after touching the gas, it is doing this error or when it is not fully heated, it gives the same error. = "0" alt = "Disapprove" title = "Disapprove" />
08.05.2020 16:22 # 4
Kemanyak
You can start by changing the gearbox oil, I think. The oil stays thick and you are loading it, the vehicle sees this mode suitable for performance in thick oil. & Nbsp;
08.05.2020 16:22 # 5
tolga35
If it does not get hot and plus when it is very hot in summer, it is useful to change the oil if there are good gear changes. When was the last oil changed?
08.05.2020 16:22 # 6
It happened to me once in the morning and after that I started the road by heating the car for a few minutes now there is no problem
08.05.2020 16:22 # 7
peugeotefe
It is useful to replace the gearbox oil and solenoid solenoid valves
08.05.2020 16:22 # 8
cetin
Solenoids are going to be 2 right? I guess they added up the car last week & nbsp; in service maintenance, I poured the oil and added it. But I don't know what oil it is. Is the gear oil different?
08.05.2020 16:22 # 9
peugeotefe
Transmission oil is different solenoid 2 pieces if you change them, the problem disappears
08.05.2020 16:22 # 10
cetin
actual
