fault that no one found
14.04.2023 00:07 # 1
Gurkan Alp
Hello friends, my car is a square coil used in a 99 model 106 1.4 xr automatic vehicle, can we convert it to a normal flat coil?
14.04.2023 18:47 # 2
Berkay Erdinc
When was the last time the fuel filter was changed.
Has the fuel pump been checked. Have the pressure of the pump checked by the clock
14.04.2023 22:27 # 3
Gurkan Alp
the float and pump were changed as a set. It has been 1 month (bosch original) fuel filter (PSA) has also been newly installed. last friday at the weekend
I think it's an electrical thing now, I'll find a nice master after the holiday
18.04.2023 19:42 # 4
Babafarabi
Sir, the battery may be old, it may not have enough power for the second starter, there may be a problem with the regulator, or the alternator cable may be old, it may not be feeding the battery well. Have these been checked?
18.04.2023 22:14 # 5
Gurkan Alp
Battery is Varta, 3 months old, measured, no problem
30.04.2023 01:54 # 6
mahmut alpay
It could be the BSI or BSM brain, it goes crazy when it comes into contact with SI. Mine wasn't stopping either, even though I turned off the starter, it got better when the brain was fixed. I've seen and experienced many problems with Peugeot's BSI and BSM brains, they're a bit of a curse. You can look for the farm that won't shut down, the wiper that won't turn off, the horn that won't work, we've overcome all of them. Thank goodness I'm struggling with oil burning and oil reduction these days, I have a plan to do it.
01.05.2023 22:33 # 7
Gurkan Alp
Well, I'm saving money. It's a nice car, it consumes less fuel and is suitable for the purpose, but unfortunately, it has many chronic problems. I don't think of anything anymore. I want to drain the tank completely and try it with fresh gas. Even my electrician and mechanic are crazy about it. I don't want to spend more or have anyone mess with it anymore.
