Fault sign on the 207 panel
08.05.2020 17:03 # 1
pandora
A wrench shape appears when I start my vehicle in a place that says mileage for a few days, and it says -100 next to the key..this sign is blinking. I would appreciate if you have any information about this subject and share it ... thanks for your help in advance ...
08.05.2020 17:03 # 2
Your vehicle's periodic maintenance time has come and goes. If you haven't done so recently, your master may have forgotten to reset the counter. Then you can reset it yourself. How many kilometers ago did you do your maintenance?
08.05.2020 17:03 # 3
pandora
it will be about 1 year after the maintenance .. but I have done 8000 km after the maintenance .. It says -100..I have done 50km at least in 2 days..the figure has not changed.
08.05.2020 17:03 # 4
It can't be anything different. Your vehicle is due for maintenance. Get a general overview as soon as possible. & Nbsp;
08.05.2020 17:03 # 5
pandora
ok..thank you..the soonest time i will see the maintenance .. thanks ...
08.05.2020 17:03 # 6
[QUOTE = pandora] ok..thank you..when i see it as soon as possible..thank you ... [/ QUOTE]
How many kilometers of your vehicle?
08.05.2020 17:03 # 7
pandora
At 59000km ...
08.05.2020 17:03 # 8
In most cases, the oil + oil filter, the diesel filter, the air filter and a few things will need to be replaced if it has not changed. Especially try to use original products in filters.
08.05.2020 17:03 # 9
pandora
I think the air filter had changed in the past maintenance ... they left 2 parts similar to the accreditation in the trunk of the car.
08.05.2020 17:03 # 10
[QUOTE = pandora] I guess the air filter had changed in the past maintenance ... they left 2 parts like the accordion in the trunk of the car..If I don't remember the mistake they were the air filter..but how much do you think this maintenance holds? [/ QUOTE] absent in Turkey
I have no knowledge on the prices. The motor that will hold the most here is oil. If you prefer a quality fully synthetic oil, it will be a little more expensive but not bad.
I personally change the air filter every time. It is not very expensive and has a direct effect on the race. Reviews
08.05.2020 17:03 # 11
tellotello
[QUOTE = pandora] I guess the air filter had changed in the past maintenance ... they left 2 parts like the accordion in the trunk of the car..If I don't remember the mistake they were the air filter..but how much do you think this maintenance holds? [/ QUOTE] Even if the air filter has changed in the past maintenance, replace it in this maintenance, which is 20 lira or a little more, and I think there is also a pollen filter. As Koliva Hodja said, it is time for maintenance, when you have done the maintenance before that, I guess you did not get your attention, after turning the ignition one turn, the remaining maintenance time comes first and then how many kilometers the vehicle is. I guess it did not attract your attention because the number is positive. It decreases and decreases over time. But I guess it doesn't fall with your km because I think the decrease in (positive) is not continuous, as if waiting a bit and collectively falling, but it is falling. The oil and oil filter is 100-odd lira. Ask the oil for service, if you want to put a different or higher quality oil than the oil they say we will put, take the oil, we will say we buy filter + workmanship, but when you calculate it does not exceed the price I say. He told me 10 thousand km of service or 1 year for oil. Occasionally check the oil condition, open the bonnet and check the dipstick. "Let's change it every 3 days (30 thousandth km) for the diesel filter," said the master. If it hasn't changed before and if you haven't changed it before, get the advice of a master's adviser, it varies according to the vehicle, but I guess I changed it because I couldn't trust that I bought my car second hand. Say you have come to the maintenance of 10 thousand, the master will also check other things. In general, this routine maintenance work (depending on the service, location may vary) should keep 200-250 or something, but as I said, one can say more and one less. Absolutely and absolutely - I think - use original products, if necessary, wait at the beginning to see the parts (if you will take them to a special service).
08.05.2020 17:03 # 12
pandora
Thank you very much, friends.
