Fault light flashes
08.05.2020 20:03 # 1
GiTaRRa
Friends, I do not know how many people had this problem, but the masters could not find any care. sometimes doing 5 km 10 times. vehicle 1.4. hd
08.05.2020 20:03 # 2
iammanover
Master, I had the same problem. Connect it to another com.
08.05.2020 20:03 # 3
erendumlu
I would say finish the warehouse and use Shell eurodiesel and try it. It is likely that he is doing it due to poor quality fuel.
08.05.2020 20:03 # 4
GiTaRRa
My friends, I get from bp, I was getting from opet before. I changed it now. I wonder if I clean the same oxygen sensor.
08.05.2020 20:03 # 5
erendumlu
[QUOTE = GiTaRRa] My friends get it from bp I was getting it from opet before.
You will not lose anything from trying, but definitely connect the vehicle to a pp2000 and read it instantly on the road. Maybe you catch something like that.
08.05.2020 20:03 # 6
GiTaRRa
Yes, I do not lose but I do not breathe. Because the flow meter is not cleaned, a new one is bought or it comes out.
08.05.2020 20:03 # 7
erendumlu
[QUOTE = GiTaRRa] Yes, I do not lose but I do not breathe. Because the flow meter is not cleaned, a new one is taken.
I said clean the oxygen sensor in response to the problem. Flow meter is a separate case. Risk of flow meter distortion is much higher than oxygen sensor
08.05.2020 20:03 # 8
necmettin
greetings friends. I joined your new break. My car 2012 model 207 pejo ruban move 1.4 diesel. I want to have my vehicle equipped with multimedia navigation. what are your recommendations? or do you have a second hand? tþkler
08.05.2020 20:03 # 9
GiTaRRa
The problem was solved, the software was discarded, the gas was broken with a reaction meter or similar name.
08.05.2020 20:03 # 10
ALLEX
[QUOTE = GiTaRRa] The problem is solved. The software is discarded. The gas is distorted by the name of the reaction meter.
I'm glad your problem is solved.
But we have learned about such a mistake.
Thank you for sharing, ..
