Fault detection device
08.05.2020 16:42 # 1
GiTaRRa
friends, I want to see if there is a performance failure of the vehicle since I will remain as pug cu from now on, industry or service only needs 20 lira to connect to the machine. / font>
08.05.2020 16:42 # 2
GiTaRRa
said that it is suitable for all models of peugeot. related seller
08.05.2020 16:42 # 3
If I was you, I would have paid a little more and buy PP2000. You would help yourself and those around you. This device is much more limited than PP2000. Of course, the price is cheap for him, but I would still prefer my choice for PP2000.
08.05.2020 16:42 # 4
istanbullu_3886
This device does not show the exact malfunction, if you look at it, it performs as if it were on the face.
08.05.2020 16:42 # 5
GiTaRRa
Tsk for your recommendation, but if the pp2000 is sold on the internet, does it make sense to buy it if anyone knows about the price?
08.05.2020 16:42 # 6
[QUOTE = GiTaRRa] Tsk for your advice, but if the pp2000 is sold on the net, does it make sense to buy it? Does anyone know about the price? [/ QUOTE]
There is no doubt that there is a seller on the Internet. I think Turkey market should be around £ 400-500 a month, but I think it will be worth it ErUmdUr get PP2000. Reviews
08.05.2020 16:42 # 7
istanbullu_3886
i agree with my koliva brother i don't say pp2000 anything else
08.05.2020 16:42 # 8
Alicilik
This device scanner
Don't worry about this, there is bluetooth water, I'll send it at half price, if you want, you just read the errors. If you have an Android phone, you can measure it as 0-100, except for the features mentioned in the announcement.
Getting the device is not a problem but the software is having trouble.
ScHerZo 2012-04-13 23:23:01
08.05.2020 16:42 # 9
GiTaRRa
I found pp2000 friends 329.00 lira both pejo and citroen suitable apparatuses or something very successful. I've seen it, I'm using galaxi S2 android but will it be able to do pp2000?
08.05.2020 16:42 # 10
bulent 77
After you can't fix the problem in Pp2000 ... how many times will you give this money and use it ... as if it was unnecessary.
08.05.2020 16:42 # 11
[QUOTE = bulent 77] After you can't fix the problem in Pp2000 ... how many times will you give this money and use it ... as if it was unnecessary.
Why can't you fix it? Reviews
08.05.2020 16:42 # 12
bulent 77
[QUOTE = koliva] [QUOTE = bulent 77] After you couldn't fix the problem in Pp2000 ... how many times will you give this money and use it ... as if it was unnecessary.
Why can't you repair it?
[/ QUOTE] this device says I will buy the locator in the friend already to detect. why fix it? & nbsp;
08.05.2020 16:42 # 13
[QUOTE = bulent 77] this device says I will buy the locator in the friend already to detect. Why fix it? [/ QUOTE] Of course you are right in the istir you will know. The thing I want to say and often encounter is water. Usually, our masters attach the vehicle to PP2000 when there is a problem in the vehicle and go directly to change the part that gives the error, which is the error that is written there. For example, they give the oxygen sensor error and replace the oxygen sensor. They then see that the vehicle repeats the error. However, the error is not from the oxygen sensor. For example, if the vehicle has some form of burning disorder, the oxygen sensor may fail. However, again, for example, one of the spark plugs is faulty. I am therefore in favor of buying PP2000. At the very least, you see the errors yourself and search the internet and go to the solution. Sometimes there are such simple mistakes that people cannot find the error even though they spend money in the world. In the UK-based peugeot forum, almost all active members have PP2000. They even made a map and marked whoever has PP2000. If you need it, you are looking at the nearest from the map, you are going and you are looking at your friends for free at all times. I think something can be done tall to be in Turkey. Here is the map: http: //maps.google.co.uk/maps/ms? Msid = 202820360806052061726.0004b10d21627263e1b9c & msa = 0Belcica is probably a device that every peugeot lover should have at hand. I think it is a product worth investing in. koliva2012-04-14 10:33:51
08.05.2020 16:42 # 14
bulent 77
[QUOTE = koliva] [QUOTE = bulent 77] says this device will get the locator in the friend to detect it already. Why fix it? [/ QUOTE] Of course you are right in the istir you will know. The thing I want to say and often encounter is water. Usually, our masters attach the vehicle to PP2000 when there is a problem in the vehicle and go directly to change the part that gives the error, which is the error that is written there. For example, they give the oxygen sensor error and replace the oxygen sensor. They then see that the vehicle repeats the error. However, the error is not from the oxygen sensor. For example, if the vehicle has some form of burning disorder, the oxygen sensor may fail. However, again, for example, one of the spark plugs is faulty. I am therefore in favor of buying PP2000. At the very least, you see the errors yourself and search the internet and go to the solution. Sometimes there are such simple mistakes that people cannot find the error even though they spend money in the world. In the UK-based peugeot forum, almost all active members have PP2000. They even made a map and marked whoever has PP2000. If you need it, you are looking at the nearest from the map, you are going and you are looking at your friends for free at all times. I think something can be done tall to be in Turkey. Here is the map: http: //maps.google.co.uk/maps/ms? Msid = 202820360806052061726.0004b10d21627263e1b9c & msa = 0Belcica is probably a device that every peugeot lover should have at hand. I think it is a product worth investing in. [/ QUOTE] If you can make one person a device that will work for 10 people, not you, you are right.
