Fault Codes
08.05.2020 21:01 # 1
maximusti
Hello friends
I scanned one of you today because I felt a low traction in my vehicle,
gave the following error codes
P2140 - Inconsistency error between the position of the accelerator pedal and the signal of the hard point contactor.
was giving this error too long ago, I think it was trying to turn on speed limiting. or something else alert
P0494 - Engine coolant function integrated in the engine computer.
I could not find out what this error was, the master I always went to didn't know, he especially controlled things about the cooling water, did not find a problem, and I traveled about 15,000 km and had no problem.
P1110 - Wealth regulation
this mistake came out new, okay, we are poor, but the bs of the car understood from this one :)
I researched a little bit about them on the internet, but I couldn't find anything really clear.
Is there anyone who gets these error codes or has information about them?
the vehicle entered the last maintenance 2000 km ago, oil filter etc. complete new changed.
08.05.2020 21:01 # 2
P2140: firstly, a problem related to the glaze, my brother, I think it was disassembled, including the sockets. gotta try. Don't forget to clean the gas pedal sockets, brother. of course, do this with oil-free contact spray.
P0494: this is caused by insufficient cooling, possibly a problem with the fan, check fan roles and resistance, clean sockets. I hope there is no problem with the fan motor.
P1110: As for that, my brother is associated with the ignition system, due to the map sensor and coil spark plugs.
In addition, one may have triggered a fault value faults. I think you should first clean the throttle and turn to the spark plug and coil.
08.05.2020 21:01 # 3
maximusti
[QUOTE = sonerkyl] P2140: first one is a problem related to the glaze brother, I think it includes disassembling and cleaning sockets. gotta try. Don't forget to clean the gas pedal sockets, brother. of course, do this with oil-free contact spray.
I wanted to clean the throttle before, we did not handle it again because my master said that if the adaptation problem, we will try very hard.
fan roles etc. let me check it, the temperature is generally high in the city but there is no problem that I observe when turning on the fan and when the fan turns on,
the spark plugs have also changed, and in the maintenance I had built 2000 km ago, we also replaced the spark plugs.
08.05.2020 21:01 # 4
laedri
First, delete the error codes, which ones will come back.
08.05.2020 21:01 # 5
I think Mustafa may be getting more air from the ignition system or air hoses if he has a rich opposite error. but it seems to be related to the throttle.
08.05.2020 21:01 # 6
emrahsen55
Hello friends, I have received the following malfunction codes respectively,
P1351
P0409
P1462
P0489
these errors came out of the master of the industry,
I'll be happy if you can help me
08.05.2020 21:01 # 7
[QUOTE = emrahsen55] friends hello I got the following malfunction codes respectively,
P1351
P0409
P1462
P0489
emrah your problem glow plugs and curve valve problem bro. egr stuffed probably do the cleaning. If not, you will change or blind the second option. there will be problems with the exhaust inspection. high values. glow plugs need to change.
08.05.2020 21:01 # 8
emrahsen55
My brother, I changed the glow plug, then I replaced the egr valve sensor, they wiped from the manifold with the würth spray for egr cleaning, but the malfunction light in the engine did not go out, they just went out while the market was walking around the market, then it burned again, friends say they use high speed ,, Also, is there any other cleaning of egr like removing it completely
08.05.2020 21:01 # 9
If the interior is dry, spray it is difficult to clean. If you want, use a cycle as a friend says on the ring road, for 10-15 minutes, 4 gears 120-130 maybe a possibility can be corrected. Even though you have changed the glow plugs with the 1351 error, there may be a problem with the relay or the installation.
08.05.2020 21:01 # 10
emrahsen55
I understand brother, let me use it as you say, I hope we will find a solution ,,, I hope we will not sail to tall costs :)
08.05.2020 21:01 # 11
kod06
My friends vehicle is working and stopping back when I start. I connected it to the obd device it gives p0463 fault code. What is the problem? What is the solution? Is there someone who can help me? Thanks in advance Smile
08.05.2020 21:01 # 12
emrahsen55
Why P0463 fault code occurs when the fuel level is normal?
  • Fuel level sensor may be broken.
  • The fuel level sensor might be displaced.
  • Corrosion may occur in the fuel tank.
  • There may be a brain malfunction.
I found them, Master, get well soon
08.05.2020 21:01 # 13
kod06
Thank you, teacher. Could this error code have something to do with the car stopping while running?
08.05.2020 21:01 # 14
mkirgoz
Friends gave these errors in my car
I would be glad if you could help.
Peugeot 307 1.4 Gas & LPG 2006 Comfort Model
P1152
P0170
mkirgoz 2020-02-08 23:52:33
08.05.2020 21:01 # 15
[QUOTE = mkirgoz] Friends gave these errors in my car
P1152
P0170
p1152 oxygen sensor error
p0170 fuel filter may be clogged or something related to bad fuel.
08.05.2020 21:01 # 16
peu307
Maybe the subjects are not the subject, but when my car peugeot 307-2004 automatic gear car is going on its normal course, the car starts to not eat gas and the speed does not exceed 2500 and the speed decreases to 30 km. Although I root the gas, the speed does not exceed 30km at 2500 speed. The vehicle does not stop, but there is a fluctuation in the vehicle speed while parking. The throttle that I took to the master said it gives malfunction error. But this is not always continuous. what do you think is the reason ??
