Fault code help
08.05.2020 20:40 # 1
cr1me
Hello respectable forum members Can you help with the following malfunction codes? Vehicle: peugeot 307 serie 1 (01-05) - 2005 model diesel. Engine code: 8hz vin 6-8 bosch edc 16c3 mt / at.
Malfunction code: p1351 (raster control circuit faulty)
Fault code: p0234 (engine overtravel condition)
I would be very pleased if you can inform exactly what is how much.
08.05.2020 20:40 # 2
p1351 bro this error code is caused by glow plugs usually needs to change. Glow plugs come into play as the weather gets cold, one or more of them are no longer function. Although the piece is cheap, it is necessary to take care of the drink while the dismantling is possible.
If p0234 is useful for controlling the turbo-egr valve and hoses, have it checked immediately or it may cause big expenses.
08.05.2020 20:40 # 3
husem
The glow plug was broken, it costs a lot. It happened to me on my c4. 1 of them was broken.
08.05.2020 20:40 # 4
Beyinci_Ugur
P1351 glow relay may be defective or bsi disconnected The glow outputs can be understood by checking that most psa are also available, this fault does not light the fault lamp
The other malfunction is that the mechanical westgage adjustment tooth ratio on the turbo is very clear, if the turbo max pressure is set to 1600 mbar, the problem will be eliminated and the most accurate setting makes the turbo.
Best regards.
08.05.2020 20:40 # 5
cr1me
Thank you very much, thank you for your time.
