fault code ??? |
| 08.05.2020 17:04 | # 1 |
| 08.05.2020 17:04 | # 2 |
If the airbag breaks out, you will deceive the system but you will resist and the room will not be very durable & nbsp; other airbags will not hurt in the event of an accident or you will go out and get the airbag.
| 08.05.2020 17:04 | # 3 |
The front two airbags break out ... I don't think of the resistance. Because let's not get out of our humanity while selling both life and life .. :) I was curious about this malfunction code. because even when the fault lamp is not lit, when we connect it to the pc again, the code gave: p2250 unknown fault code
| 08.05.2020 17:04 | # 4 |
The link below says that there is a problem with the oxygen sensor voltage. Delete the error, drive a little bit, and then see if the error comes back. http://www.permoveo.ltd.uk/tabid/122/OBD-Error-Code/P2250/Diagnostics/Peugeot/Default.aspx |
