Fault 307 XT Premium 2005 - Petrol + Lpg
08.05.2020 20:53 # 1
yazici61
Hello ,
I bought my car about 1 month ago. There are some problems in the car for 3 days, I would be glad if you can help.
Tube brand: Landirenzo
First of all, when my vehicle exceeded 110 km in the morning 2 days ago, it started to sound from the tube indicator as if the tank was over. Then the engine fault light started flashing and I immediately pulled over and waited. Then I started it again, but the vehicle did not switch from gasoline to LPG, and there was a sound when I pressed the button. I used it a bit like this, although my car was not over 110 U after the accelerator pedal.
2. distress The vehicle eats gas, the cycle is rising fast, but the vehicle is accelerating at night, I thought it was a pressure pad.
When I brought the lpg problem to the master, he connected it to the device and gave the injector and map sensor malfunction no.4. When I said what the cost would be, it would find 2000 TL. 4 injector composite switch map sensor what I do not know. If you want the same master to me for a little over a century, I was unstable when I said a new installation to 1500.
Is the price affordable, can I find a different solution? I will be happy if you help
08.05.2020 20:53 # 2
My teacher injector and map sensor told me if the car does not have its own petrol injector or injector and map sensor of the lpg system. if the lpg system is injector two kinds. evo series is 550 tl map 130 tl master is quite a fly so i mean what is master trick official 2000 tl. 1500 zero atiker obd gets 2 lpg, and even the inspection and sealing rapruna will remain.
08.05.2020 20:53 # 3
yazici61
He said the injector of the tube. Sorna said herself, let me make 1500 new installations
[QUOTE = sonerkyl] My teacher said that the injector and the map sensor did not have the vehicle's own petrol injector or the injector and map sensor of the lpg system. if the lpg system is injector two kinds. evo series is 550 tl map 130 tl master is quite a fly so i mean what is master trick official 2000 tl. 1500 zero atiker obd gets 2 lpg, and even the inspection and sealing rapruna will remain.
08.05.2020 20:53 # 4
Well, my brother, the man is flying, and he is looking for a man to pile on the best quality. 130 TL map sensor, which gives 550 TL injectors, 680 TL materials, let's keep 750 TL, 100 TL pattern, no heavy workmanship. 850-900 tl max. it must be with workmanship.
08.05.2020 20:53 # 5
yazici61
I don't get it either. I was waiting for 1000 liras or something
08.05.2020 20:53 # 6
As I said, you can take the teacher parts from the internet and assemble them to another master. or you can add another 500 TL and install a zero lpg kit.
08.05.2020 20:53 # 7
yazici61
thanks, i will ask you something more
They made a price of 700 Lira for the printing pad.
As I said [QUOTE = sonerkyl], you can take my teacher parts from the internet and assemble them to another master. or you can add another 500 TL and install a zero lpg kit. [/ QUOTE]
08.05.2020 20:53 # 8
My brother, let me tell you, if the original is going to be installed, get the guarantee of having it installed in the service. If you get the original piece out of service, I want to inform you that there is no guarantee.
700 TL is very demanding, the master teacher will receive 350 TL 350 TL labor. labor requires a lot only for clutch
sonerkyl 2018-05-25 15:44:08
08.05.2020 20:53 # 9
yazici61
I did not solve everybody too much from me :)))
08.05.2020 20:53 # 10
09XR
Where is the mab sensor in the vehicle?
