fault
08.05.2020 17:01 # 1
lead38
Hello friends & nbsp; My car has 2004 model pejo partner 1400 engine lpgli.Lavato & nbsp; gas brain.
& nbsp; I'm tired of this malfunction light. It does not burn anyway, but it does not burn, but the car does not pull for a certain time, it crashes. As if the car ramps down, the light is on while climbing the loaded ramp. It is as if the car is paralyzed. Pozantı d lamp burned traction is over I pulled hard to the right & nbsp; I waited for half an hour & nbsp; the traction improved a little I could come to Kayseri.
& nbsp; They said & nbsp; the catalyst is clogged. the brain doesn't recognize lpg & nbsp; they said & nbsp; so & nbsp; lpg & nbsp; was not suitable for the car. He said, "The ramps said," Get off the ramps with gasoline & nbsp; then it doesn't do it & nbsp;.
& nbsp; & Nbsp; Now what should I do & nbsp; does a good & nbsp; master a lpg & nbsp; fine & nbsp; settle this job (could be a poor mix or something) Some said & nbsp; gasoline should not be less than a quarter of a tank. Is it possible?
& nbsp; & Nbsp; & nbsp; Disgrace me This fault has an absolute solution & nbsp; can you help. "Clap"
08.05.2020 17:01 # 2
yenice
Is there such a thing as to get out of the ramp with gasoline? God bless you, I hope a friend who has experienced the same problem and found a solution gives information.
08.05.2020 17:01 # 3
lead38
God bless
08.05.2020 17:01 # 4
lead38
do not have masters of this forum
08.05.2020 17:01 # 5
It is quite normal that you get the oxygen sensor error because you have drained the catalyst. As long as you are not misleading, that error will always come. You may also not be able to go through the inspection.
Your vehicle must be connected to the computer and see what the problem is. The problem is in the LPG equipment, since you did not do this event on gasoline. A good LPG master can solve your problem & nbsp; I believe.
Also, our new members need to introduce themselves before opening the subject. Please provide a link to the link in my signature.
koliva 2012-09-01 05:53:32
