Fat reduction :(
08.05.2020 16:27 # 1
Ucyuzalti
Friends I went to Ankara & nbsp; I have traveled a total of 600 km. If the distance between the two lines on the dipstick is 1 liter
the car is 300-400 gr. I guess the oil has decreased. "C Vehicle travel & nbsp; very nice lpg even with the tip of the gas, the pressure of 130 - 150 is nice, but nie do not understand it, i use castrol 10-40 as oil, blue smoke blowing & nbsp; vs no engine at 145000 vehicles
08.05.2020 16:27 # 2
Most vehicles correspond to 1 liter between the minimum and maximum lines on the oil jar. Was your vehicle on a smooth ground when I was measuring? How was the engine temperature?
08.05.2020 16:27 # 3
Ucyuzalti
It came from Ankara engine & nbsp; "LOL" I pulled on flat ground I waited for 5 minutes, I looked, I saw the eye decline, because without leaving Ankara & nbsp; I looked at it, it was reducing before, I think it was burning due to lpg at high temperatures. Next time I think about using mobile 10-60 oil. /smiley5.gif "border =" 0 "alt =" C o nfused "title =" C o nfused "/> & nbsp;
08.05.2020 16:27 # 4
albayman
If the engine is not finished, you may have measured incorrectly. maybe he's missing somewhere.
At 170 thousand km corsa gls was missing from the carter gasket in my 1.4 lpg car. & nbsp; 2 months after I got the seal, I made & nbsp; Aydın ankara Aydın. I traveled a total of 1200 km in 20 hours. I measured the oil, especially before I left and after the trip. There was no gram decrease.
08.05.2020 16:27 # 5
I think 10W-60 is too much income. I would try one of the fully synthetic oils that I would try 10W-60 if I was in place. & Nbsp;
08.05.2020 16:27 # 6
Ucyuzalti
How did you know you missed the seal? How much did the decrease occur? How do we suddenly use the room over time?
08.05.2020 16:27 # 7
Ucyuzalti
Doesn't it burn the full synthetic more & nbsp;
08.05.2020 16:27 # 8
ugur_clskn
mobil 10 60 as far as I know it is fully synthetic. I have seen its benefits when I have 306, you can try it.
08.05.2020 16:27 # 9
Ucyuzalti
I am thinking about trying, how can I control the leakage master? Bid this would be a problem in 10-60 winter? I will be happy if you give information about the pros and cons of this oil "Smile"
08.05.2020 16:27 # 10
Ucyuzalti
It was such a good performance of the car, but it broke my morem when it did something like this "Sleepy"
08.05.2020 16:27 # 11
albayman
[QUOTE = Three Hundred] Six How did you know you missed the gasket? How much did the decrease occur? How do we suddenly use the room over time? [/ QUOTE]
vehicle was lifted on the fiber, six checked. it was already obvious that the lower part of the carter was oily. It was found by following the trace that the leak flowed ...
08.05.2020 16:27 # 12
Ucyuzalti
There is no cover sheet under the cartel, and when it is lifted in the fiber, there was a little oil in 2 places, I looked at a good tool.
08.05.2020 16:27 # 13
yavuz25
My friend put in 20/50 oil. If you haven't got the engine done, 20/50 goes well .;)
08.05.2020 16:27 # 14
djchaos
lpg de oil reduction would be weather conditions, lpg can decrease the oil in such factors may miss the oil cartel & nbsp;
08.05.2020 16:27 # 15
Ucyuzalti
There is nothing under the cartel, it is incomprehensible if there is a leakage from the scheme & nbsp;
08.05.2020 16:27 # 16
Ucyuzalti
We should accept 20/50 engine & nbsp;
08.05.2020 16:27 # 17
yavuz25
Of course. Why not? I was putting 20/50 in our old car too.If I put it a little thinner, the oil would decrease.It wouldn't be hard in the winter. .gif "height =" 17 "width =" 17 "border =" 0 "alt =" Wink "title =" Wink "/>
08.05.2020 16:27 # 18
Ucyuzalti
I asked someone & nbsp; He said that he would disrupt the oil pump or something, he is okay if he accepts & nbsp; "Big there is a decrease in oil but I don't know how it is I'm glad, but I will change castro bilom & nbsp; & nbsp; "Big
08.05.2020 16:27 # 19
yavuz25
My oil pump would be broken? If you put oil and oil additives higher than 30 & nbsp; you would say it would break down. = "17" width = "17" border = "0" alt = "Wink" title = "Wink" />
08.05.2020 16:27 # 20
yavuz25
but by the way, the number of the gearbox oil is VERY IMPORTANT. "Wink"
Page : / 2
