fat reduction
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 19:36 # 1
usta307
WHY DOES THE ENGINE EXTENS OIL?
Every engine can lose some oil. In the vehicle catalogs, it is generally stated that the vehicle will know a little oil. The statement of the experts, on the other hand, is interpreted as the loss of more than 1 liter of oil per thousand kilometers above the normal values.
1- It may leak due to engine seals or damage to the cartel.
2- Because of the piston rings are worn, oil may leak into the combustion chamber.
3- If blue smoke comes out of the exhaust pipe while the engine is running, it is a sign that the rings have been leaking oil into the combustion chamber.
4-Valve tires may cause the oil leaking into the combustion chamber to burn and cause blue smoke to emerge from the exhaust due to too hard or damaged.
5- Pistons and cylinders are worn. In such cases, strange noises can be heard from the engine.
6- Cylinder body is multiplied by tightening the cover bolts.
7- The gap between the records of the intake valve and the valve stems has grown enough to allow oil to leak into the cylinder.
8- Since the vacuum pump diaphragm is drilled, oil is absorbed from the sump to the intake manifold.
9- The excessive wear of the main and connecting rod bearings causes excess oil to splash on the cylinder walls.
10- The pressure of the lubricating oil has increased too much due to the defective or clogged oil pressure control valve.
11- If the piston pins are lubricated with pressure, loosening the pin increases the passage of oil into the cylinder.
12- Very thin oil is used in the engine. Or because the quality of the oil, which is suitable thickness in cold, is not good, the engine gets thinner when it gets hot. For this reason, the oil consumption of the engine increases.
13-The engine of the car is very compacted, it is used aggressively, and if high speed is used, it may cause the engine oil to decrease.
I thought it would be useful.
