Fat loss
08.05.2020 15:42 # 1
deamod
I changed the oil of my car, it was 5-6 days, but when I looked at it, I looked at the bottom to see if there is less oil left from a scratch again, but it does not flow in the oil.
08.05.2020 15:42 # 2
cerci07
Are you sure you fill the oil when you make a change? If you changed the filter after changing the oil, did you run the vehicle a bit and check again? If you do, he may be missing from the bung. Even if the vehicle burns oil, there is no possibility to burn it
08.05.2020 15:42 # 3
deamod
I checked the plug, I changed the filter, yes, but I did not check it after starting it, if it has something like that, if it is not filled, that master will draw from me ...
08.05.2020 15:42 # 4
deamod
a spike of pearl plug
08.05.2020 15:42 # 5
Well Then :) Your Eye is Aydın ...
08.05.2020 15:42 # 6
deamod
I'll gum.: D
08.05.2020 15:42 # 7
[QUOTE = deamod] I'll glue: D [/ QUOTE]
The Tapay? Would be funny Gülme
Try to squeeze a little more. Get a new gasket that didn't. 3 TL.
