fat gauge freaked out
08.05.2020 14:14 # 1
300yedi
Good evening, friends, yesterday evening, I changed the oil of the car to something like oil.
car 1.4 hdi 307 5 & 40 oil I did not put castrol 10 & 40 turbo diesel oil, the sound of the car decreased, would it be a bit harmful to this hot car?
08.05.2020 14:14 # 2
Why the oil level does not appear in our indicators
08.05.2020 14:14 # 3
When the oil level indicator turns on the ignition, it appears on the km indicator before starting the car. There is a letter F ..
08.05.2020 14:14 # 4
300yedi
It shows on digital display showing km. shows oil level after the maintenance mileage
oooo_ _; There are 6 levels like ooooo_ if all of them are round, fat is full, if there are lines next to the circles, the oil level is as low as that line. usually exits at the time of pressing marsa, usually after the maintenance km
08.05.2020 14:14 # 5
PCcolog
Do not rely on that indicator, be sure to check it from the bar. Sometimes it does not delete the memory for a long time and shows it incorrectly.
08.05.2020 14:14 # 6
dnzalkn
that indicator usually shows right, but when it shows right when the engine is completely cold, the oil is drained from the engine back into the oil chamber. Turn off the ignition after the engine has run for a long time, then the oil gauge sometimes min. is showing
08.05.2020 14:14 # 7
dogu
there is no such indicator in 2006 307 Ağlama
08.05.2020 14:14 # 8
ali oncu
Do not trust the indicator with certainty, mine shows a full demonstration, there is nothing, but there is oil.
08.05.2020 14:14 # 9
voodoo
The important problems of the pugs have not been put on track of these indicator situations yhaa :(
08.05.2020 14:14 # 10
bestfear
The same problem exists in my vehicle ... oil full-time indicator shows only ... master indicator said from the client ... bestfe is 2010-10-21 23:54:33
08.05.2020 14:14 # 11
serkan24577
[QUOTE = ali Öncü] Do not trust the indicator, I will definitely say that there is no full demonstration, but there is no oil. [/ QUOTE]
CHANGE THE OIL ON TIME CONTROL YOUR HEAT TO A MAXIMUM WEEKLY OIL TO MAKE YOUR HEAD COMFORTABLE
08.05.2020 14:14 # 12
PCcolog
Look at the cleanest bar. The more electronics, the more problems :) My mind is constantly mislead.
08.05.2020 14:14 # 13
bulent 77
My motor must be cold and the vehicle must be straight.
