Fan Turns On And Doesn't Exceed 3000 Rounds
08.05.2020 21:20 # 1
xlarc
Hello friends,
I have a 2012 Model 206+ Diesel Vehicle. When I got into the car today morning, as soon as I started the car, the fan turned on and I saw that it couldn't exceed 3000 cycles when the car moved, This is why this problem is caused. CryCry
Thank you in advance for your help
xlarc 2019-10-09 11:19:25
08.05.2020 21:20 # 2
First of all, welcome to us. My teacher must first look at the fault codes of the vehicle. The motor does not exceed 3000 cycles because it protects itself. check the vehicle water and oil.
08.05.2020 21:20 # 3
fkundak
I need to look at the vehicle with diagnostics, but it seemed to me like a catalyst system failure behavior.
08.05.2020 21:20 # 4
ismailkaya
Connecting to the device is the most guaranteed catalyst top oxygen sensor. But why does the fan turn on directly? Did you look at the water in the reserve tank, the hose may have burst. Normally you may not see sin burst, but when you squeeze the vehicle, it will throw water from the burst hose and you should look carefully. motor protecting
