fan problem
08.05.2020 17:54 # 1
foresteng.
Hello,
My car 2006 model gasoline 1.4 automatic Feline 206 ... For the first time with this vehicle, I went the long way. All maintenance was complete (oil, water, etc.) İstanbul-Bartın; Bartın-İstanbul I had planned a 3-day trip. However, I realized that the fan was constantly working on the last stage on the road ... So I had to take a break every 3-4 hours .. The hareret hand comes to 90 at the ramps, while traveling on the normal road between 70-80. it goes and goes .. yet the fan works like crazy. There is no water reduction. As far as I know, the sender had changed. I heard there were 2 sender with this engine, right? Is the continuous operation of the fan from the client?
In addition, when the temperature gauge was 90, I got stuck on the gearbox, and even though I took the manual, I still saw the D symbol on the screen and I could not use it manually. When I took a break, I realized that everything returned to normal when the car cooled down.
* In the meantime, it was a surprise to come up with gasoline ...
08.05.2020 17:54 # 2
error
how many thousand are the vehicle? Has the timing changed? Has the circulation changed with the timing?
08.05.2020 17:54 # 3
foresteng.
My vehicle is at 74600 km .. I do not remember trigiy so the owner before me gave the change notes made, but now I can remember ..
08.05.2020 17:54 # 4
Turgay_66
the sender may be broken, your air conditioner may be turned on, the sender has a header, it may be slightly above the thermostat.
08.05.2020 17:54 # 5
foresteng.
Thank you, I will have it checked as soon as possible. The air conditioner did not matter on or off ..
08.05.2020 17:54 # 6
koray
Try removing and reinstalling the battery cap
08.05.2020 17:54 # 7
foresteng.
Which one?
Is it +? - is it?
08.05.2020 17:54 # 8
koray
When my vehicle suddenly turned on the stop lamp, it was moving, stopping the vehicle, disconnecting the battery head and waiting for 1 minute, then I re-installed it was getting better again. +
08.05.2020 17:54 # 9
foresteng.
ok .. i try ...
