Fan often turns on when idling 206!
08.05.2020 17:38 # 1
Turgay_66
Guys, I'm sorry, I created another topic, but my problem has not been solved yet. Please help when the car is idle, the 2000 model 1.6xt 206 heats up very often and it turns on the fan frequently, the fan cools down 2 minutes later, it gets hot again and the fan turns on again. no problem on the long way but .. Turgay_66 2013-05-30 01:14:07
08.05.2020 17:38 # 2
rolandgarros
Does the vehicle gas itself?
08.05.2020 17:38 # 3
Turgay_66
No, everything works normally, but the idle indicator rises immediately at idle, the fan turns on, the fan stops, turns on again after 2-3 minutes.
08.05.2020 17:38 # 4
KenBlockJR
my car was doing the same too, the coolant temperature sensor was faulty when it was connected to the computer
08.05.2020 17:38 # 5
tellotello
Have you checked the thermostat, overheat and fan consumers? Does the vehicle turn on the fan immediately when running at idle (when cold) and without moving? What I mean is, maybe the water inside the engine is not actually heating, but the sensors turn on, thinking that the sensors are hot. If there is a way to measure the temperature of the water in the system (as soon as the fan turns on) and comparison is made (I know it is seen when it is connected to the computer), this type of situation can be learned or not. I think you had your circulation pump checked, didn't you? If your circulation pump has a propeller (this may not be the full name), there may be an increase in idle speed in the vehicle. Get well soon.
08.05.2020 17:38 # 6
Turgay_66
Thank you very much for your help, my teacher, when I changed that part. I just bought the car and started to cool just because of this problem, where is the part of the car and how much is it?
08.05.2020 17:38 # 7
Turgay_66
My teacher, I called the guy I bought, the circulation pump has just changed. There is no problem, but as you say, the sensor measuring the temperature may be defective. I will go to the industry tomorrow. Turgay_66 2013-05-30 11:19:23
08.05.2020 17:38 # 8
KenBlockJR
if you change it, it will probably recover. I did not see, I did not change :)
08.05.2020 17:38 # 9
Turgay_66
How do you never get annoyed that your car often opens a fan :)
08.05.2020 17:38 # 10
Aziz
I experienced this situation in 3 pejoms. No problem idling the fan on my old 2 pejo vehicle.
While waiting at idle in the current pajom, when the air is above 30 degrees, it rises to almost 100 degrees, the fan stays on. the important thing is the warning lamp is on?
08.05.2020 17:38 # 11
Turgay_66
No, my teacher, the warning lamp does not light up, but often it goes between 90 and 100. Can the movement indicator be from the heat sensor?
08.05.2020 17:38 # 12
Aziz
[QUOTE = Turgay_66] no teacher warning lamp does not light up, but often it goes between 90 and 100.
Let me now explain in detail.
my first vehicle was the 306 xr 2001 model,
and I met the first pejo (except bike)
the temperature rises, the fan turns like a fan, never stopped.
I went to the service. They said the temperature sensor. They dressed 50 TL, the problem was not solved, I went again. They said thermostat. If you want 89, if you want it, they said low or something, we found it difficult for 85 but we found it, it did not change again, we had changed its water. then we came across an industrialist who used pejo for years. these friends are already working with warm blood and after a certain age they talked like boiling blood after a certain age and shared on this site I learned this topic in time that it was warm blooded, then 206 x-line automatic bought the room likewise opened fan at idle idle idle
These are the vehicles that will even find 100 when the traffic is congested like stop and stop, which is 3 km from the house with this vehicle. The indicator still exceeds 95. When I turn off the ignition, the fan continues for 2 more minutes. I'm not a problem.
08.05.2020 17:38 # 13
Turgay_66
I understood my teacher, my first car and my first pug :) I have never seen it in other cars, so it turns on a fan so I'm looking at it as a problem but I am surprised what I will do because some of them work like this ..
08.05.2020 17:38 # 14
Aziz
Slowly add water or something.
08.05.2020 17:38 # 15
Turgay_66
When I say add water slowly, there is no water reduction, I couldn't understand.
08.05.2020 17:38 # 16
Aziz
yes I think it is ok if there is no water reduction,
Yes, in 3 pejoms, stop in hot weather or stand idle fan is making ceiling.
Also, if it doesn't do it on the long road, this is a positive situation. If the temperature is high then it can be said that there is a problem.
08.05.2020 17:38 # 17
Turgay_66
There is no problem on the long road, my teacher, thank goodness :) then we have to get used to this fan voice in the city and in the lights :)
08.05.2020 17:38 # 18
Aziz
I repeat, this is my point of view and I had no problems.
I did not hear any fan noise until the weather got warmer that when I used the vehicle I used at 6500 rpm more and the temperature was the same :)
but my other 2 vehicles are normal use and in this, when I go out to travel, even while waiting at the traffic light, the fan opens up lions :)
08.05.2020 17:38 # 19
Turgay_66
I understand, thank you very much, teacher, you sprinkled water in it :)
08.05.2020 17:38 # 20
allppeerr
hocam turkey you know the steepest ramps your black, 40 km'm going continuous ramp and does not rise fervor and I would advise you to have it checked if you have LPG on your speed I use a tool that LPG with your vehicle as someone who has a lot of tools automatic vitesse transmission cooler b I would recommend that you install them how many parts today In the forum posts, there was a friend who suffered from the same trouble and wrote the name of that piece.
Page : / 3
