fan is always running
08.05.2020 14:16 # 1
barisaso
I left 206 for air conditioner leakage repair and gas filling yesterday, I got it to service yesterday, but it drew my attention to the continuous operation of the fan.
08.05.2020 14:16 # 2
Shouldn't there be a problem in Mushur? or a problem in the fan motor
08.05.2020 14:16 # 3
barisaso
I looked at it in the morning today, it was not working after parking, I said let's open the air conditioner and look at it.
08.05.2020 14:16 # 4
erkan samur
hello in 206 above 20 models, i.e. in vehicles with multiplex system, if you do not turn on the air conditioner when the vehicle first starts, there is no problem if the fan is activated at 90 degrees, it is normal, when you turn on the air conditioner, the fan runs at low speed, this is also normal when the air conditioner is turned on, if the fan does not stop after turning off the air conditioner it's about gas pressure. 206 fabrication value is 575 gr, but it does not happen 480 gr gas should be pressed for the best coldness and the fan will return to normal.
