Fan does not turn on when the temperature exceeds 90
08.05.2020 17:41 # 1
baroff
Hello friends, my car overheat 90 does not turn on the fan does not open until 110s, the fan auto electrician said it is done until the morning leave until the evening, he said long work, do you think it would be so long?
08.05.2020 17:41 # 2
emre_akdag
Dude your thermostat is out of order. It will replace the thermostat. Its equivalent is 30-35 TL. I do not know how much workmanship will take. Or he has another job.
08.05.2020 17:41 # 3
fatihgg
it hurts towards the vehicle 110a, check the murniir first, there is a cheap and short method.
08.05.2020 17:41 # 4
baroff
Thank you guys, let me show you certain pieces as you said.
08.05.2020 17:41 # 5
sayginotp
My friend, your vehicle's fan resistance is probably faulty, but it is the healthiest solution that the master needs to connect to the computer and check that the system is working properly. In peugeot vehicles, the fans start to work at 98 degrees, stop at 90 degrees, the second circuit of the fans starts to work at 110 degrees.
08.05.2020 17:41 # 6
nevce
I had the same problem, when I went to the master, he connected it to the computer and said no problem, it opens at 97 degrees, but it stays 80 on the straight road.
08.05.2020 17:41 # 7
Your vehicle is tested by connecting to the healthiest computer. If you say water tap fan on the computer, you will check if it is going to open and you will see if it works or not. There is no need to heat the vehicle again to try it. If the fan is on, but still not hot, then there is a problem with the thermostat, as the emre says.
08.05.2020 17:41 # 8
baroff
Hello friends, I got it done today. Fan sensor changed, air conditioner gas changed, I paid 150 lira more?
08.05.2020 17:41 # 9
rolandgarros
[QUOTE = baroff] hi guys I got it done today. Fan sensor changed, air conditioner gas changed, I paid 150 lira more? [/ QUOTE]
it has been finished, never mind, never worry, your mood will be disturbed. LOL
08.05.2020 17:41 # 10
baroff
[QUOTE = rolandgarros] [QUOTE = baroff] hello guys I got it done today. Fan sensor changed, air conditioner gas changed, I paid 150 lira more? [/ QUOTE]
Hodja, I know, I wouldn't take the car to the same places according to him.
08.05.2020 17:41 # 11
emre koksal
If the fan is running too loudly, the fan motor needs to be replaced. 135 TL parca fiat..you find 160 sales with craftsmanship ..
I wanted to do it in sasmaz and make it to the master.
08.05.2020 17:41 # 12
hLL
[QUOTE = koliva] Your vehicle is tested by connecting it to the healthiest computer. If you say water tap fan on the computer, you will check if it is going to open and you will see if it works or not. There is no need to heat the vehicle again to try it. If the fan is on, but still not hot, then there is a problem with the thermostat, as the emre says.
When I go to the service, I will say this and have it checked, and I don't hear the fan voice. Does he work very quiet? Dead
08.06.2021 22:11 # 13
Durak akkaya
[QUOTE=respect notp]My friend, your car's fan resistance is probably faulty, but it would be the healthiest solution for the master to connect it to the computer and check that the system is working properly. In peugeot vehicles, the fans start to work at 98 degrees, stop at 90 degrees, and the second circuit of the fans starts to work at 110 degrees.[/QUOTE]
