Fan and heat problem
08.05.2020 19:37 # 1
Dzking
Sa friends. My problem is that as I opened the fan contact, the 2nd period is either constantly running or working, it keeps working, even in these cold days. The temperature is passing through the middle, sometimes it does not open at all, the temperature is rising, the recuperative recirculation has changed, the fan has a heat-free radiator antifreeze and the air is taken, the roles are not attached, I could not understand I did not try. Nowadays, the signal is accelerating when the brake is pressed. One of the fog is not burning sometimes. Does the car have a short circuit? The car did not accept the ECU PC connection. Please let me know and I can help everyone.
08.05.2020 19:37 # 2
Dzking
Friends who have an idea.
08.05.2020 19:37 # 3
talip206
Yes, there is a high probability short circuit. Check all retrofitted accessories. Such as tape, amp, lpg, xenon, amerkan park, fog light. Probably not a competent person intervened and pulled the wrong cable.
08.05.2020 19:37 # 4
Dzking
When my talented brother bought a car, there were no such problems. Later, the amp and tape were connected only. I don't know, I showed it to the electrician, he says we should disassemble it completely. I don't want the car to be too hard. Since Ecu connection could not be made, one had to test one by one. In other words, the car, which does not see the middle line, stops at the line under the red, it is easy to stand up, the fan always works, it comes on and goes out continuously or during the heat, I do not understand when the jac acmiyoe presses the a / c button, but if the haba is recovered, I will look at everything first. Hopefully thank you for your comment.
08.05.2020 19:37 # 5
Dzking
Do you have friends to offer other information and suggestions? May everyone be easy
08.05.2020 19:37 # 6
ihsanozlesmis
[QUOTE = Dzking] Do you have any friends to offer other information and suggestions? Make it easy for everyone [/ QUOTE]
Is there an A / C in the vehicle, Brother?
08.05.2020 19:37 # 7
Dzking
Yes 106 gti vehicle with rug
08.05.2020 19:37 # 8
Dzking
I forgot to say that there was a small leak from the car radiator, I added an intermediate additive. But I don't think this will cause trouble
08.05.2020 19:37 # 9
ihsanozlesmis
Brother.It's Reading The Temperature Value Of The Car Wrongly And Thinking Hot And Turning On The Fan.
Air Conditioner (I think this is the problem)
Temperature sensor
Heat Sensor
Problem One of these 3 check the plugs one by one check.
08.05.2020 19:37 # 10
Dzking
Fan switch is brown, I opened the new changed commander and pulled the fan one by one while the fan did not stop. Then I took it out, then I made it, and it comes back on again. I tried a lot of annoying things. The vehicle opens a fan, my brother
08.05.2020 19:37 # 11
talip206
Then the problem is most likely in the amplifier and tape connection. For example, if you signal when someone of the signal lamp bursts, the signal sounds fast. You said it yourself, the signal accelerates when you press the brake. There's a short circuit somewhere. Remove the bidet stop and turn signal lamps and see if there is any water or rust oxide. But again I say the problem is in the amplifier or tape connections
08.05.2020 19:37 # 12
ihsanozlesmis
Doesn't It Stop When I Turn Off The Ignition, Brother?
08.05.2020 19:37 # 13
Dzking
There is no need to start the contact, the last stage is running after the last gas, then it runs intermittently.
08.05.2020 19:37 # 14
Dzking
I hope my brother, I hope, if the weather is nice, I will remove all the headlights and look again. I will cancel the amplifier and the tape temporarily. We will be saved.
