falling out of traction and stopping |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner | |
| 08.05.2020 20:40 | # 1 |
Hello friends. I am the newest member of your club and I am pleased to meet you. When I took it to the repairers, they said that some pump is bore, some are pointing incorrectly, some are pouring holes in the float hoses in the gas tank, the tank must be removed and the hoses must be replaced. such a malfunction may have happened to you. I would appreciate if you help. Thanks in advance for your interest. |
| 08.05.2020 20:40 | # 2 |
I think your warehouse is dirty. Or there is a problem with your diesel filter. These problems, which are close to the end of the warehouse, generally occur for two reasons.
| 08.05.2020 20:40 | # 3 |
Oktkor |
I think clean the tank. Then replace the diesel filter. I think it's probably due to bad fuel. After this process, press between 3500 and 4000 cycles for a half hour is on the long road. Before that, it makes more sense to see a good master. Ours is an estimate. |
