falling out of traction |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 08.05.2020 17:39 | # 1 |
vehicle `03 307 1.4 hdi xr |
| 08.05.2020 17:39 | # 2 |
actual
| 08.05.2020 17:39 | # 3 |
ilyas |
First of all, let's say, check the turbo and turbo hoses that come to my mind first.
| 08.05.2020 17:39 | # 4 |
[QUOTE = ilyas] First of all, check the turbo and turbo hoses that come to my mind first. [/ QUOTE] +1 may be drilled or exploded, buddy ..
| 08.05.2020 17:39 | # 5 |
All right, I'll check it out soon, but the hose is understandable, how can I control the turbo?
| 08.05.2020 17:39 | # 6 |
ilyas |
[QUOTE = blinddark] all right, I will look at it soon, but the hose is understandable, how can I control the turbo? Can I do it? the car drops from the traction at the same time, the car starts to smoke, this is my experience from the vehicles I know and use, but you said the sound came, I would probably say the hose |
| 08.05.2020 17:39 | # 7 |
fexzi |
One of the stereotyped situations is diesel vehicle, especially if it is a turbo, direct turbo life. / div> How are the catalysts? & nbsp; What is the maintenance of filters and oil, they will reduce the diesel from traction.
| 08.05.2020 17:39 | # 8 |
bro, don't ever bother you, i had a benzzer incident related to 95% turbo. I don't think it will cost you much. The hose should have been pulled out because the vehicle does not accelerate at the times when full turbo will enter. Even if the hose did not come out, they say that it is the gasket that is used to tighten the hose. They say it is loose, it is loose, the air hose is taking the turbo hose should be as hard as possible because the air pressure to the engine & nbsp; can't do it and falls out of traction .. water hose came out too :) 12-13 key screwdriver and pliers I solved my job:) & nbsp; By the way, if there is a recommendation ready for the maintenance of the vehicle, there are engine cleaners, it is incredibly effective. Mixing 400 grams of diesel or the place you buy says you how to use satin, etc. It cleans the institutions, then the air filter oil filter and oil has changed its water better than before :)
| 08.05.2020 17:39 | # 9 |
Now I opened the hood, I removed the black cap on top, what I see is the pain I looked at, the length of the torn hose is about 2 inches of the length of the hose coming from the left side. The length of the hose is 15 cm. I said, he called and returned to me, and now I will go out of my way and follow my ost.
| 08.05.2020 17:39 | # 10 |
ilyas |
[QUOTE = blinddark] I opened the hood now, I removed the black cap on top, what I see is what I see from the pain I looked at, the length of the torn hose about 2 inches from the left side, the average 15 cm of the hose is located on the turbo hose, there is a black square plastic bisey there, I immediately called my father turbo hose I said you would call a mechanic torn, he said he called me and returned to me. . div>
| 08.05.2020 17:39 | # 11 |
[QUOTE = blinddark] I opened the hood now, I removed the black cap on top, what I see is what I see from the pain I looked at, the length of the torn hose about 2 inches from the left side, the average 15 cm of the hose is located on the turbo hose, there is a black square plastic bisey there, I immediately called my father turbo hose I said, "Do you call a mechanic?" I said, "I will call you a mechanic," he said, and he returned to me. There is a reason. There is a reason. .. god do not have a train accident :)
| 08.05.2020 17:39 | # 12 |
I went to the industry and when the hose was changed, the time of maintenance was approaching, the hand was thrown in order to get out of the way; turbo hose oil filter air filter pollen filter diesel filter oil front right and left brake discs front right and left brake pads I gave good money including these changing parts workmanship, but do you think you can give an idea of how much they are in total
| 08.05.2020 17:39 | # 13 |
tellotello |
[QUOTE = blinddark] I went to the industry and when the hose was changed, the maintenance time was approaching, so the steps were taken to get out of the way; turbo hose oil filter air filter pollen filter diesel filter oil front right and left brake discs front right and left brake pads div> these changed parts I gave good money including workmanship but do you think you can give an idea of how much they are in total [/ QUOTE] div > turbo hose oil filter air filter pollen filter diesel filter oil (10w40) general control + two small screws or something blah & nbsp; div> I gave them 290 weeks 2 weeks ago & nbsp; |
| 08.05.2020 17:39 | # 14 |
The problems were solved when it came to the road, but I did not know, but did anyone know what the price of the front pads and discs are?
