Falling from power
08.05.2020 21:21 # 1
Pejoant
Hello friends
My vehicle 1.6 engine 2000 model 75 horsep hb pejo 206. Gas & LPG
There is no interruption in power while gasoline is also going to power, but after 2 300 cycles, the power is cut off. It is as if the trend is restricted. It goes well until 2 300 cycles. 2 After 300 cycles, it feels as if they put a thick sponge under the pedal, making it difficult to press. How can I handle this problem. Does anyone know why this happens? Thank you in advance Shocked
Pejoant 2019-11-09 20:19:49
08.05.2020 21:21 # 2
Karacocuk24
[QUOTE = Pejoant] Hello friends
[/ QUOTE] If my brother is doing it because of LPG, all you have to do is show it to a good LPG master, I don't think it will be something you do.
08.05.2020 21:21 # 3
probably the problem with the lpg installation is that the system will not make sure that the gas cutters are working properly. then you have the lpg injectors checked and finally the regulator problem.
