Fainting at 307 Hdi Ramp
08.05.2020 19:48 # 1
stain1903
Friends have a good day 1.4 307 hdi pressure pad has been changed, maintenance has been done. It goes up to 170 km on a straight road, and when it sees the ramp, it passes out. There is a steep ramp that knows between Tekirdag and Malkara. I go 100 km with megan. This was also happening quickly before the press changed the pad. I know the car is not waste, but even the brodway turns out fast, the master said the car was normal, but the horse's horsepower was enough, or is there a missing or inoperative situation.
08.05.2020 19:48 # 2
teacher, change the location where you take the fuel, and try the wür fuel additive. when was the last fuel filter changed?
08.05.2020 19:48 # 3
stain1903
[QUOTE = sonerkyl] Teacher, change the place where you take the fuel and try to add wur fuel. When was the last fuel filter changed? [/ QUOTE]
It has been 3000 km but it does not change when it is new. I have used fuel fuel, but I guess it wasn't wurt. I bought the fuel from different places, there was not much change :)
08.05.2020 19:48 # 4
Check the air filter boiler and hoses and see if it can be torn open.
08.05.2020 19:48 # 5
stain1903
[QUOTE = sonerkyl] Check the air filter boiler and hoses and see if it can be torn open. [/ QUOTE]
Thank you very soon.
08.05.2020 19:48 # 6
Faruk
[QUOTE = stain1903] Friends have a nice day 1.4 307 hdi pressure pad has been changed, maintenance has been done, according to the master said the turbo has no problem. It goes up to 170 km on a straight road, and when it sees the ramp, it passes out. There is a steep ramp that knows between Tekirdag and Malkara. I go 100 km with megan. This was also happening quickly before the press changed the pad. I know the car is not waste, but even the brodway turns out fast, the master said the car was normal, but the horse's horsepower was enough, or is there a missing or inoperative situation. [/ QUOTE]
Look at the turbo hoses and the hoses of the air filter, sir.
I had low traction, I was connecting the engine to the height of the ramp, but it turned out to be hoses.
08.05.2020 19:48 # 7
oguzhan29
Did the teacher maintain the air filter of the vehicle? Have the fork hose of the turbo look at the hose of the air box coming out of the turbo Clean the air flow meter beautifully clean the ramp up the vehicle was never going, my air flow meter was cleaned.
08.05.2020 19:48 # 8
stain1903
It has been maintained for three thousand km. It was the same when it was new, they said there was a rupture in one of the turbo hoses, they changed it, but the situation was the same
08.05.2020 19:48 # 9
oguzhan29
clean the flow meter, look at the values of my teacher
